Old 09-09-2019, 12:26 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
^^^^^^^^^ are those wheel covers ....called deluxe wheel covers by the PHS folks ?
No, these are the standard wheel covers that came on the car when you didn't choose any optional cover or wheel.
  #62
Old 09-09-2019, 12:47 PM
428ho4spd's Avatar
Default Started on the engine yesterday.
Pulled the radiator and front of the engine apart to have the original radiator recored and water pump rebuilt. It was pretty crusty in there where the coolant sat for all those years, but luckily it cleaned up good with just some minor pitting on the inside of the cover.
ID:	519785   Click image for larger version
ID:	519787   Click image for larger version
ID:	519788   Click image for larger version
ID:	519789   Click image for larger version
  #63
Old 09-09-2019, 12:51 PM
428ho4spd's Avatar
Default Divider plates & T-stat.
The divider plates are toast, but actually weren't rusted through after scraping off most of the crud. It also appeared to have the original t-stat in it, "Delcostat" - never seen one before.
ID:	519791   Click image for larger version
ID:	519792   Click image for larger version
ID:	519793   Click image for larger version
  #64
Old 09-09-2019, 12:56 PM
428ho4spd's Avatar
Default Timing gear.
Also checked the timing cam gear to see if it had been replaced, nope. Sure enough, it was the original aluminum cam gear with nylon teeth (at one time), but not a plastic tooth in sight! The chain was very loose and riding on the aluminum teeth, but it never jumped time. Got the front of the block cleaned up pretty good.
ID:	519795   Click image for larger version
  #65
Old 09-09-2019, 01:00 PM
428ho4spd's Avatar
Default I found the steering box.
For some reason this box was covered in grease and grime on top. While I was in there with the degreaser, I went ahead and cleaned the top side of it, came out real nice. If it has a bad leak, I'll find it now!
ID:	519799   Click image for larger version
  #66
Old 09-09-2019, 01:06 PM
428ho4spd's Avatar
Default Took valve covers off.
Was glad to see the inside of the heads were very clean, no sludge at all. Even the underside of the valve covers were perfectly clean. Rex must have changed the oil regularly.
ID:	519801   Click image for larger version
ID:	519802   Click image for larger version
ID:	519803   Click image for larger version
  #67
Old 09-10-2019, 11:07 AM
Cardo's Avatar
Cardo Cardo is offline
Wow! I can't believe how clean that motor is inside. Water pump was suprising too!
"I know just enough to keep me here, but not enough to get me out"
  #68
Old 09-15-2019, 04:38 PM
428ho4spd's Avatar
Default Storage decal on front of RH cylinder head.
While removing the passenger side smog pump bracket, I found this underneath it. Has anyone seen one before?
  #69
Old 09-15-2019, 10:44 PM
OG68 OG68 is offline
Is there a big time difference between the casting date of the block to the rest of the components or build date?
2007 Cadillac SRX
Old 09-16-2019, 12:38 AM
428ho4spd's Avatar
No, actually everything is pretty close... E and early F dates throughout. Block and water pump are F027, heads are F057 and intake is E257.
ID:	520236   Click image for larger version
ID:	520240   Click image for larger version
ID:	520241   Click image for larger version
  #71
Old 09-16-2019, 11:28 AM
Thats only a little over three weeks from casting to vehicle build date. Figure in the transit time to the west coast, that doesn't leave anytime to be stored.
2007 Cadillac SRX
Old 09-19-2019, 06:56 PM
geeteeohguy's Avatar
Great catch on the timing chain.....and just in time. You are doing all the right stuff and really doing this rare gem justice. Keep the pictures coming!
Jeff
  #73
Old 09-20-2019, 12:29 PM
Nice find.
1974 Formula 400 - Ram Air automatic
  #74
Old 10-11-2019, 08:30 PM
Mike Davis's Avatar
I heard the California AIR cars didn't run well and weren't worth much. PM me your address and I will drive out and take it off your hands before you invest too much in it.
Nice score.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
  #75
Old 10-11-2019, 11:02 PM
428ho4spd's Avatar
Nice score.
LOL... nice try!
Thanks!
  #76
Old 10-11-2019, 11:23 PM
428ho4spd's Avatar
Default Removed the intake & valley pan to take a look.
Not much new to report lately, been on a little break. I did go ahead and remove the intake and valley cover since I already have new gaskets for them. Also wanted to check out the inside of the valley and be able to pour some fresh oil onto the cam and lifters. It was very clean inside there too, but dry. I did find one piece of plastic from the old nylon timing gear that was lying in a recessed part of the valley. I'm guessing that it must have been thrown up there by the crank through one of the open passages along the camshaft?
ID:	522014   Click image for larger version
ID:	522015   Click image for larger version
  #77
Old 10-12-2019, 01:19 AM
brut4s's Avatar
brut4s brut4s is offline
WOW! Awesome find. Hope to see it at a show one day
  #78
Old 10-12-2019, 11:27 AM
The more you show us of that car, the better it looks!
Old 10-19-2019, 03:28 PM
428ho4spd's Avatar
Default Funky Intake Port... expert opinions, please...
Forgot to post these photos earlier... should I be concerned with this casting booger and partially blocked opening of this one port? I really hate to mess with it if its not a big deal. The "booger" is rock solid by the way, its not breaking loose on its own.
ID:	522466   Click image for larger version
  #80
Old 10-19-2019, 06:23 PM
Mike Davis's Avatar
Since you have the intake off I would go ahead and grind that off. May not ever come loose but they way my luck runs it would hang a valve, bust a piston and crack a block.
