Old 09-10-2019, 08:26 PM
davidgto davidgto is offline
Default gto wheels value
What are a set of original 65 GTO steel wheels valued at?? I have heard, whatever someone is willing to pay, but I would like an expert opinion..
Old 09-10-2019, 08:28 PM
rare4k's Avatar
rare4k rare4k is offline
No expert but range is 60-100 per rim condition is also a factor
Sent from my moto z3 using Tapatalk
Old 09-10-2019, 08:39 PM
Default xxxxxxxxxxxxxx
Thanks. Any other thoughts or opinions appreciated.
Old 09-10-2019, 09:07 PM
bill ryder's Avatar
bill ryder bill ryder is offline
What number or letter is stamped by the valve stem hole???
"Bill"!
Old 09-11-2019, 11:16 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Photos please of stamped letters, numbers on outside.
Plus photos of information on the inside (date code, etc.).
Thanks.
Old 09-11-2019, 12:13 PM
Default xxxxxxxxx
Wheels are in another state. I think they are authentic ,but do not want to ask many questions at this point that might drive the price up. If they are authentic, what do you fellows think they are worth. A reasonable value as I plan to flip them at a reasonable price.
Old 09-13-2019, 02:25 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
After reading this looked at the wheels that were on the 65 project I have. Three have GM65 on a raised area and either a 6 or a 9 by the stem(depending on which way is up). 4th wheel no stampings and looks a little different so probably not correct.
Skip Fix
Old 09-13-2019, 08:21 PM
bill ryder's Avatar
The 3 with a 6 are 65 correct.
"Bill"!
Old 09-14-2019, 09:31 AM
Skip Fix's Avatar
Thanks Bill.
Skip Fix
Old 09-17-2019, 10:21 AM
dld's Avatar
dld dld is offline
There is a date code on the inside . that would be hidden buy tire . it is very light in stamping.
also a code at the valve stem (6) in 65. there were no other letters or numbers at v.s.
there were two mfg. Norris and Kelsey Hayes. Norris Tech.were found more on west coast cars.
when I was looking for a set for my car . I found them VERY hard to find. I think I payed as much as $225 a wheel . and man I had a hard time finding a set . two years looking.
ID:	520401   Click image for larger version
ID:	520402   Click image for larger version
Old 09-17-2019, 10:42 AM
dld's Avatar
dld dld is offline
But the side story was I found a lot of wheels for other years that I sold to help pay for the 65 wheels LOL
Hope your next step is not to find a set of custom deluxe hub caps in concourse condition
Old 09-17-2019, 11:04 AM
72pontiac's Avatar
72pontiac 72pontiac is offline
was a part number stamped on Norris wheels on the outside outer edge by where the bead would seat
Old 09-17-2019, 11:36 AM
Condition, Condition, Condition in each particular application of stock wheel is what determines a fair market value. Finding or putting together a matched set that were removed many decades ago & properly stored up off the ground, preferably indoors, improve the odds of the wheels being clean & easily usable.
Stretched lug nut holes, heavily rust pocked areas where the tire beed seats, heavily bent outer lips, all are problem points that can render the value from really low to scrap metal.
Old 09-17-2019, 12:06 PM
60sstuff's Avatar
OEM Originals on my 65 Survivor. Baltimore built 11A.
Letters and numbers match on all 5 wheels.
Date code on inside (9 64) = Sept. 1964.
All codes on this 65 are Aug./Sept. of 1964.
I’m not sure what the 186 means in grease pencil on the inside of one wheel.
The 186 day of 1964 is July 4, 64.
Chris.
ID:	520407   Click image for larger version
ID:	520408   Click image for larger version
ID:	520409   Click image for larger version
ID:	520410   Click image for larger version
Old 09-17-2019, 01:55 PM
Skip Fix's Avatar
So do others have the GM65 stamping also? The GM is above the 65.
Skip Fix
Old 09-17-2019, 01:59 PM
dld's Avatar
dld dld is offline
Chris.
The W as i understand meant Weld. The number on the inside of wheel may have been a job number . look at your trim tag on cowl Baltimore put a job number on tag . the wheels / tires were built off line and had a job number on them
Old 09-17-2019, 02:03 PM
dld's Avatar
dld dld is offline
don't be mislead buy the JK code on inside . that was the wheel outer ring only not the assembly.
Old 09-17-2019, 03:09 PM
60sstuff's Avatar
Well, the job number is 686, and my one wheel is marked 1 86.
Could be something related?
ID:	520424   Click image for larger version
ID:	520425   Click image for larger version
Old 09-17-2019, 04:17 PM
dld's Avatar
dld dld is offline
you can find chevelle wheels also or 442
second box to the right note the code (6)
this is a list of a later year than 65. I think 1966
see pic of chevy codes and fitment
Name:	Copy (2) of DSCN1427.jpg
Old 10-06-2019, 10:25 PM
Skip Fix's Avatar
Here is the GM65 and the 9 or 6. If you use the GM65 it is a 9.
ID:	521675   Click image for larger version
Skip Fix
