What are these holes in my firewall for?
Hi Everyone...I was hoping to get some help on what these holes in my firewall are for. I have done a bunch of research and I think I have good ID's on most of them.
Here is the key: Red with labels = I'm pretty sure what attaches here... Blue with labels = something that needs repaired Green with numbers = I need to know what attaches here or if it needs to be filled. Thanks in advance for the help. |
4&5 are for the screws for the fuse box. 1,3&7 and several that are labeled grommet are for the rubber push pin for the firewall insulation. Trying to figure out where your horn relay holes went to?
"I know just enough to keep me here, but not enough to get me out" |
What are the 2 holes in the blue rectangle for? I've seen them on a/c and non a/c cars. Thanks
Those holes appear to be from an installation of an aftermarket a/c unit, there is also a hole drilled in the floor for the drain hose. I'm planning on trimming out the metal between the holes and welding a new piece in that area.
Thanks to Cardo's help I have done a little more research on the firewall pad. It looks like that pad has 7 push through fasteners. If that is correct then at this point hole #2 is the only mystery...
Does #2 belong on a factory firewall? Thanks. |
I Just checked (a picture) of my firewall, and it doesn't have a hole at #2, but there is a dimple there. Drilled by previous owner possibly? My firewall does not have hole #6 either. Any idea what that one is for?
Thanks for the help. I have no idea on #6 but I did find a picture posted by Mr. Boneske where I it looks like it is present. A PO my have drilled the #2, the underside of the dash looks like it had a gauge set hung. Not a bad spot to run an oil line to a pressure gauge.
Same here, a dipple.
Thank you Cardo and NYGTO...I guess I will weld it up.
