Old 09-26-2019, 11:01 PM
Hank Hank is offline
Default 64 Motor swap
Can anyone tell me why when I took the 6 banger out and put in a 389 with factory 64 manifolds why the front of drivers side manifold is almost on the rag joint? Manual steering. I used the correct frame and motor mount's
Old 09-26-2019, 11:31 PM
242177P's Avatar
242177P 242177P is offline
Frame brackets are side specific. The taller one should have been installed on the driver's side.
Old 09-26-2019, 11:35 PM
Default 64 motor swap
It was that's what's got me confused
Old 09-26-2019, 11:40 PM
Default 64 swap
I took the frame mount's from a 64 Goat and bolted them on just as I took them off
Old 09-27-2019, 01:06 PM
Chris65LeMans's Avatar
Post some pictures.
Old 09-27-2019, 01:30 PM
The frame mounts are side specific. They were produced with different bolt patterns so there would be no chance of mounting them on the wrong side, so that rules that out as being a possible cause.
Here’s what your clearance between the exhaust manifold and the rag joint should look like.
ID:	521017   Click image for larger version
Old 10-11-2019, 03:50 PM
B-Man.. I see now what my problem is from your pics. I tried to put pics on here to show my problem and it would not let me for some reason. It's my manifold pipe, it looks nothing like the one in your pic. My pass side is correct, the casting number on my drivers side pipe is 9773442. With that being said does anyone have a correct drivers side pipe for my car? Thanks, Hank
Old 10-11-2019, 04:56 PM
1_Wild_Cat's Avatar
My references show that part number as the correct exhaust manifold for a '64 GTO.
Old 10-11-2019, 11:30 PM
Default motor swap
Yea, mine to. That's why I bought them . But my manifold looks nothing like B-Mans pics
Thread Tools
Display Modes
