Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-06-2019, 06:04 PM
Scott65's Avatar
Scott65 Scott65 is offline
Default MSD 8528 w/BOP gear, and blaster 2 coil
For sale: MSD 8528 distributor with BOP composite distributor gear, and blaster 2 coil.
This is a great distributor for street or race. Will work with or without an MSD box. Can be locked out for race (or street), and can be run with full adjustable mechanical advance, and vacuum advance. Is currently locked out, but springs and weights, and vacuum canister are included. (As well as the lockout vacuum stub attached) Has a BOP composite gear, will include the MSD gear as well. In great shape, only removed because I went coil per cylinder. No cap, it will accept a factory style cap, or an MSD cap.
$375 shipped CONUS only. The BOP gear is $125 new, so the price is reasonable, and firm.
ID:	521647   Click image for larger version
Old 10-06-2019, 08:39 PM
GTOLou GTOLou is offline
I'd have an interested in just the dizzy and dizzy parts.
I don't need the coil or BOP composite gear.
Old 10-06-2019, 08:54 PM
Scott65's Avatar
If I can get someone who's interested in the gear and coil, I'd be fine with that. But until then, I'm not gonna break it up. If you want, I can get back to you if/when that happens.
Old 10-06-2019, 11:07 PM
CatalinaMike CatalinaMike is offline
What would you want for the BOP gear and what size is it?
Old 10-06-2019, 11:21 PM
Scott65's Avatar
It's for the .500 shaft the MSD distributor uses. PM me if that's correct for what you're needing.
Old 10-07-2019, 02:16 AM
Went to check the dist but found no "MSD" markings anywhere on it. Will have to check my other
Old 10-11-2019, 08:19 AM
Scott65's Avatar
BOP gear sold. Distributor now comes with the original gear installed, $300 for it and the coil shipped.
Old 10-17-2019, 08:21 PM
Scott65's Avatar
Will separate.
Old 10-21-2019, 09:11 AM
fastekibeast fastekibeast is offline
Do you accept PayPal?
Old 10-21-2019, 10:45 AM
Scott65's Avatar
No. I can do Zelle, if that helps.
Old 10-22-2019, 04:26 AM
No it doesn't help, I'm out with this.
Thanks,
Janne
Old 10-22-2019, 06:25 AM
Scott65's Avatar
No problem.
Still available.
Old 12-15-2019, 11:25 AM
Scott65's Avatar
Bump
Old 02-13-2020, 11:14 AM
Scott65's Avatar
Bump. Trades considered. Need a set of tall fabricated valve covers with no holes or company logos. Or a dominator carb hat. Can add some cash for right stuff.
Old 02-13-2020, 11:23 AM
Speargun's Avatar
Speargun Speargun is offline
PM sent
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 02-13-2020, 12:37 PM
Scott65's Avatar
PM replied to. Thanks
Old 05-04-2020, 07:16 PM
74gto's Avatar
74gto 74gto is offline
PM sent
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 05-04-2020, 07:36 PM
Scott65's Avatar
Sold. Thanks PY
