7 second door car list
**Update Time** Let me know what corrections need to be made or who need to be added.
6.98 @ 199mph 4.53 @ 164mph |
I should do one for just 1/8th mile stuff.
Billy,
Are you going to do a 6 second door car list? If not then maybe make this 7 seconds or under. Stan
I thought about it but seems to be hard to get info out of people. I wish someone else would do these (hint hint)
Hope to have an update after Pontiac Heaven weekend in November, if I can get down the track.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
The problem is if the people will not give you the info they will probably not give it to anybody. If you send me the data as a text file I will format it and put it up as a web page and post the link here. Stan Weiss <srweiss1@comcast.net> Stan
Email sent
New England Dragway
August 31st 2019 535CID Twin Turbo DCI RAV C16 Fuel 60’ 1.215 330 3.218 1/8 4.872 MPH 148.79 1000 6.294 ET 7.499 MPH 186.00 Weight 3640 Let me know if you need a picture of the time slip
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Didn't GTO GEORGE make a 7 sec pass in a door car ?
Yes he did, at Norwalk this year. I don't have the exact numbers, weight and so forth. He will likely provide.
First pass.
http://www.magneticlynx.com/carfor/pont_list.htm Tomorrow I will add the new entries that are posted and try to add some color bars. Stan
Cool idea!
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
I love seeing the weight and type of car. Some heavy girls running fast!
What surprises me is the lack of turbo'd entries on the list- just one?
I don't see Rodney Butler, Cooper or John Welter?????
Look at the qualifying lists of the Q-16 and the Frantic Four?
How about Curt Geise? Probably lots of others out there. Stan, maybe put this line on next line down? Quote:
Good start and good luck with it.
Stan
2018 Frantic Four (only Frantic Four I have or found)
and 2019 Q-16
Thread Tools | |
Display Modes | |
