What IS the NHRA rule on window nets???????
I went to replace my ribbon-type window net (perfect condition, but cert expired 6-30-19) and they no longer make a net that will fit my chassis. I can have a custom-made net for $100+ shipping. In talking to a major chassis parts supplier, the guy told me it's NOT necessary to replace nets every two years, except on Pro-Mod or Pro-Stock cars. I run Super Pro. He told me to cut off the SFI cert and I would be good to go. I found that hard to believe since I was gigged (but allowed to run) a few years back for an outdated window net at Firebird, where I will be running November 1st at Pontiac Heaven.
Here's what the current NHRA rule book says: (Super Pro, Pro, Sportsman) Window Net A ribbon-type or SFI 27.1 mesh-type window net is mandatory for any full-bodied car running 7.50 to 9.99 or if vehicle runs 135 mph or faster. See General Regulations 6:3. (General Regulations) 6:3 WINDOW NET An SFI 27.1 ribbon-type or mesh-type window net is mandatory on any full-bodied car running 7.49 or quicker. For full-bodied cars running 7.50 to 9.99 or if vehicle runs 135 mph or faster, a ribbon-type or SFI mesh-type window net is mandatory unless otherwise specified by Class Requirements. SFI 27.1 window net, when required, must be updated at two-year intervals from the date of manufacture............. To me, this says what the chassis parts guy told me: I don't need a current SFI net as long as it's a ribbon-type net (in good shape). I never used to mind buying an unnecessary new net every two years when they were $40, but I'm sick of bending over for the NHRA and paying for safety I don't need just to keep the window-net manufacturers in business. For guys running 7.50 to 9.99 in a full-bodied car, what has your experience been?? Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
i had the same experience. A Tech told me i had to replace it or recertify. I called stroud and they said it is not necessary. No one has questioned it since.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I was told to remove the date tag off mine in Fla this year and then it wouldn't need to be replaced. Thought that was odd but went back to the trailer and pulled the tag. No one has even looked since.
We had the same one on Grocery Getter for 17 years. One tech guy (only) griped about the date but let us run anyway. At the time, the rule book kinda implied that they weren't needed if you had arm restraints so I got a pair from RCI, used them and nobody ever asked again.
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. The mind, once stretched by a new idea, never returns to its original dimensions. |
Thanks for the quick replies, guys. I took off the SFI tag and plan to go with the old net. I'll take along a copy of the current NHRA rules, if they hassle me.
Jim
Ours expired in 2002 So...............
6.98 @ 199mph 4.53 @ 164mph |
The way I understood it at the time was that if it had a tag on it, it had an expiration date. So needed changed.
If there is no tag then it must not have an expiration date? But it would have to appear as unaltered I would say. Don't just ripped it off and have frayed threads etc. They can reject it if the tech guy thinks it is unsafe whether in date or not. This was also pertaining to the flexplates and SFI bellhousings I think.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
Mine is 2001 never a problem..
Side question...
If you have a cage and the car runs 11's you need a window net...correct? |
Norwalk Tech came over to our site this year and said that under 7.5et, the window net needs to be changed every 2 years.
An SFI 27.1 ribbon-type or mesh-type window net is mandatory on any full-bodied car running 7.49 (*4.49) or quicker. For full-bodied cars running 7.50 (*4.50) to 9.99 (*6.39) or if vehicle runs 135 mph or faster, a ribbon-type or SFI 27.1 mesh-type window net is mandatory unless otherwise specified by Class Requirements. SFI 27.1 window net, when required, must be updated at two-year intervals from the date of manufacture.
2023 Best ET Slip 60 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Yes
7.50 to 9.99 ribbon type doesn't need to be SFI which would have no expiration.
7.50 to 9.99 mesh type is SFI and needs replaced every 2 years. 7.49 and faster needs to be SFI mesh or ribbon and replaced every 2 years.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
Never had anyone check my net...only my seat belts.
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
OK, so my next move is to gather up all my "outdated" window nets and sell them on eBay. SMH.
Jim
Who would buy them................ Nobody ever updates them LOL
You got me there.....new car or new cage??? Seriously, I have sold outdated seat belts several times. I'm not sure who buys them---off-roaders?? Jim
Circle track guys bought all of our seatbelts.
(when I was still in Illinois)
I don't have one but I'm getting close ? So I mite buy a used one ?
How much ?
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
PM sent. Jim
7.50 and faster every 2 years 7.50 and slower no time frame unless it is torn or frayed
