Old 10-09-2019, 10:20 AM
MarkS57's Avatar
MarkS57 MarkS57 is offline
Default SI & HEI Upgrade
Hi guys,
I plan on upgrading to an SI & HEI on my 65. I plan on using an M&H harness made specifically for this, any experience with these out there?
For the SI I thought of this one:
https://www.qualitypowerauto.com/ite...-regulator.htm
I figure 100A is enough as I plan on a Vintage air system in the future but no other meaningful electrical loads like massive audio amps
65 Tempest, 400, TH400
86 Fiero SE 2.8
Old 10-09-2019, 12:39 PM
Murf Murf is offline
I used the M&H one that I got from our host. Worked great for me.
Murf
Sent from my iPhone using Tapatalk Pro
Old 10-09-2019, 12:58 PM
David Ray David Ray is offline
M&H is a great wiring company, but, make absolutely sure you get EVERYTHING correct in the request. If you make a wire dimension that is too short, that IS the way they make it, no questions.
When I di a 12SI alternator, I do a simple 3 wire stocker 94 ampere Chevy Citation unit into an external single wire. 14 gauge wire from BATT to side terminal 2, done, finished, works as EVERY other external or internal jumped 12SI. From there, the large existing BATTERY cable from the old alternator, goes to the BATT terminal on the rear of the altrnator, just like the original one.
As far as powering up the HEI with a stock wiring system, look at the fuse box, fnd the IGN terminal, and check it for power in both start and run. If good, single 12 gauge wire to the BATT terminal on the distributor cap, done.
M&H will do it differently, both work same.
Old 10-10-2019, 10:03 AM
Rich-Tripower's Avatar
As far as the ignition, why not go with a Crane XRi or a Pertronix system? A whole lot less hassle to install and they work great. My Pertronix and Crane systems have been a lot more reliable than the HEI I put in my truck. It has gotten hard to find quality HEI modules and coils anymore. If you DO go HEI, be sure to buy a quality coil and try to find an old (pre-1980) AC Delco module.
Old 10-10-2019, 03:02 PM
MarkS57's Avatar
Hi Rich,
I have the HEI distributor ready to go otherwise I might have considered something else. I bought several NOS modules and coils in dusty old AC /GM boxes. I've read that the HEI might have an issue with the old external regulator alternator so that's why the SI conversion, even if that's really not the case, wouldn't hurt.
86 Fiero SE 2.8
Old 10-10-2019, 04:02 PM
wow, LOTS of misinformation floating around.
12SI IS the alternator to use, that is why the aftermarket people chose the 94 ampere Chevy Citation ones to pattern their stand alone models. Simple, and easy to just install the farm and implelent regulator inside them, makes them a single wire. What did everyone think, these after market companies figured it out, not a chance, GM did when they first designed the 12SI, one had 3 wires and outside connect for road vehicles, the farm and industrial implement one had everything connected inside it already.
Now, for the earlier remote regulator alternators, there is an after market electronic regulator that makes the earlier remote regulator alternators function EXACTLY like the 12SI internally regulated regulators, and still mounts in the stock remote location. Wells VR715, good change over if you don't want to go with a complete 12SI setup, or one of its clones.
HEI has never had adverse issues with any earlier GM alternator system, unless the alternator/regulator is defective.
An HEI, even one with dead stock parts far exceeds any after market "drop-in" ignition conversion system, bar none. YES, the HEI has inherent problems such as an absolutely substandard coil, and none of the after market coils are any better, and, hard to curve mechanical advances. But HEI's are far better than other systems that do not like to be run on full voltages, nor are anything more than a simple set of electronic points that have been over volt'd by some supposed engineer that insists that system is some sort of performance system when run on full battery volts, then fails repeatedly. Drop-in point replacement systems ARE NOT A PERFORMANCE SYSTEM, they are an electronic set of POINTS, nothing more.
Another total falsehood, "Those HEI modules, none of them are reliable, they fail for NO APPARENT REASON". Simply not true. The run of the mill HEI module will spin well past 7K RPM's, and have NO problems when a good coil is used with them. Only problem is, NONE of the coil in cap coils are worth a diddly darned. Those coils run too hot, have insulation issues, layer short, change resistance as those coil primary windings touch together, overwork the modules to failure, and do not get replaced until the very last, because others insist it isn't the coil, when it clearly is causing the module failures.
Something that also helps kill coils, is the utter myth that spark plug gaps are "OK" when set past .045 MAXIMUM spark plug gap. NOT EVEN CLOSE. GM had to warrantee replace both coils and modules on brand new vehicles when they changed the spark plug gaps higher than .o45, and the cars would stop dead in their tracks soon after being sold. Gaps for some Olds, Buick, Pontiac were "enhanced" into first, .060, then, .080, both to total failure of both coil and module, and, those failures stopped cold when the spark plug gaps were closed back down to .045. This is in a FDM (Factory Directed Modification bulletin) to all he branches, that fixed the failures.
NOTHING fails "for no apparent reason", NOTHING. Now, if you have a large HEI, and want to fix the coil potential issues, MSD has a coil adapter, and have had for about 30 years, to move the coil OUT OF THE CAP, use an oil filled round coil, that fixes the coil, and 99-1/2 of the module failure issues, including MSD box failures when those parts are used with a large HEI.
Why does the large HEI have a coil that is problem prone? Well, if the coil were oil filled, and mounted to the cap, and the coil developed a leak of the flammable oil inside it, the oil would leak out of the connector terminal on the bottom of the coil, down the carbon button, onto the rotor, where centrifugal force of the spinning rotor would position the flammable oil at the spark gap between the end of the rotor and the wire terminal inside the cap. figure the rest out for your self. end of it would be something like ....BOOOOMMMMMM!.
YES, I get really testy when I hear all this other insanity about these large HEI distributors, because I was on the team at GM that developed and designed them in the first place. Since then, a bunch of us that did that stuff have heard every moronic answer for the questions asked about them, most all of those answers way off the truth. It has been real past old, for decades.
I was also involved with Team Kawasaki Road Racing motorcycles. In the winter of 1972, I drilled the first motorcycle disk brake rotors on my own personal H2R factory road racer motorcycle, with 72 quantity, 1/2 inch holes. Since then, I have heard every reason for drilling holes in motorcycle, and car brake disks, from everybody that claimed they did it first, in like, 1980 or so. NOBODY came up with the real reason, making he brakes work better by reducing the unsprung, and rotating inertial weight of the disks, two of them on the front of my bike. Stock disk, 7.50 lbs, drilled disk, reduced single disk weight to 3.70 lbs, EACH. It is much easier to stop a 3.70 pound weight, than a 7.50 pound one. Was it MY idea? Well, frankly, NO, it came from my seeing pictures of a 1965 Can-Am racer Porsche with factory drilled disks. I just did it first on motorcycle disks.
So, lets stop all the misleading info and speculation, shall we.
Old 10-10-2019, 09:03 PM
MarkS57's Avatar
wow....
that's quite a reply
Anyway, a solid state regulator would save me a bit of coin, something to think about.
Plugs are gapped at .045"
86 Fiero SE 2.8
Old 10-22-2019, 12:27 AM
smasse64 smasse64 is offline
Dave: I do believe we've talked in past about crappy "top-of-distributor" coils...
I got the MSD coil convertor pc for the top of the coil and mounted a nice new oil filled round coil back on factory bracket on motor near dist. This summer, in hot weather, my motor failed just like it did for past three or four years in high heat on highway run....but it wasn't coil or module this time...it was vapor lock...good spark..no pump....I installed a phenolic resin 1/4" thick heat gasket under carb and some fiberglass tubing over my metal gas line going to carb...NO MORE HIGH HEAT MELTDOWNS/FAILURES this summer!!!...new gas is shietty..boils off at 140 degrees according to my chemist brother!!..my engine runs 190!..BAM!!!...no more heat problems with coil off HEI and carb running cooler gas...next is new gasket for air cleaner to keep that big heat sink from heating up my carb from the throat down!!!...
