Old 10-12-2019, 11:27 AM
lucky1 lucky1 is offline
Default Speedometer cable routing. 65 Gto 4sp
Hi, replacing the speedometer cable. Can anyone advise the the the proper
Routing ?????
Tks.
Old 10-12-2019, 05:36 PM
Default Never mind.
Discovered it's a Chev. Trans. With drive gear on opposite side. 😳
Old 10-12-2019, 06:13 PM
Tom Vaught's Avatar
Boost Engineer
Doug Nash used to offer a adaptor for his trans, (Chevy speedo gear location).
Doug went to Heaven years ago but maybe Leonard Long still has some of the Adaptor Cables that cross over the trans tailstock and connect to the Pontiac speedo cable.
Tom V.
Old 10-12-2019, 07:21 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
I would think if you say, for example, you imagined your car's cable as a '65 Chevelle or El Camino. I think that cable would be long enough. The Chevrolet Muncie 4 speed cars; their cable exits out of the passenger side so the cable needs to be longer. How much longer I do not know, but it has to cover more area to get all the way up to the dash.
Peter Serio
Owner, Precision Pontiac
Old 10-12-2019, 07:56 PM
jarhead's Avatar
jarhead jarhead is offline
I looked up a 65 Chevelle application in the Ground Up web site. - https://www.ss396.com/chevelle/FCC-2...elle&year=1965
They offer an 83 inch and a 64 inch cables. The notes for the 83 inch indicate - "This cable is intended to screw into the passenger side of the transmission".
More pictures of my former Goat:
http://www.barrett-jackson.com/appli.../w_search.aspx
My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K
And in the 2008 Scottsdale auction, Lot #960 - $80K
Eventually sold by Brighton Motor Sports in Scottsdale, AZ - http://www.remarkablecars.com/ppads/...p/product/4844
Old 10-13-2019, 12:01 AM
Rich-Tripower's Avatar
In a Chevelle (I have two 65s) the cable runs under the dash and goes through the floor on the passenger side of firewall near the beginning of the transmission hump. It then is a fairly straight shot to the transmission. But if you try to run the speedo cable from a hole in the firewall on the driver's side you will either run out of cable (even with a correct Chevelle long cable) or have to take bends that are too sharp. The trick is to run the cable through the floor on the passenger side.
Or, you could just locate a tailshaft housing with the speedo cable connection on the (wrong) driver's side. To me, the Chevelle version makes more sense as you can easily get at the speedo gear housing without mucking with the shifter or crossmember. If you'd like I can scan a page from the Chevelle assembly manual showing where to place the hole in the floor pan and how the cable should be routed.
ID:	522054   Click image for larger version
ID:	522055   Click image for larger version
Old 10-13-2019, 11:56 AM
Default Thank you.
As they say a picture is worth a thousand words, Lol
If it would be easier, my Email is cbrooks971@gmail.com.
Thanks again, sure looks like the way to go.
Old 10-13-2019, 12:30 PM
Default Chevelle speedometer cable ?
Looked at Chevelle speedometer cable ((84").
The ones I saw only had a screw on collar on the trans side of the cable ?????
Found a 83" cable with collars on both ends, would 1" shorter be an issue ????
Thank you.
Old 10-13-2019, 01:53 PM
Murf Murf is offline
Thank you.
Shouldn’t be. I have Chevy trans in mine. I believe Ames sells + lengths or Rock Auto lists the lengths in the descriptions.
Sent from my iPhone using Tapatalk Pro
Old 10-13-2019, 01:55 PM
The hole for the speedometer cable in the Pontiac A body car is in the floorpan, on the driver's side. Here is a drawing from a kit to install backup lights in a '64 Lemans or GTO. In the drawing, they show an arrow; you can see part of the speedometer cable for a Lemans or GTO with a Muncie 4 speed transmission.
All of the '64-70 Buick, Olds and Pontiac (A body) Muncie 4 speeds had the cable exit out from the Driver's side of the tailhousing.
Not sure if even an 84" long cable could come from around a Chevrolet Muncie up thru the factory drilled hole in a GTO. It would probably have wrap around and go underneath the bell-housing.
Name:	64-65 GTO_Backup Lamp Wiring Muncie 4 speed Hurst.jpg
Peter Serio
Old 10-13-2019, 03:19 PM
Here is a page from the 65 Chevelle Assembly Instruction Manual showing how the speedometer cable is to be installed in a 65 Chevelle for the 4 speed (cable attaching on the passenger side). The grommet used is a simple rubber o-ring grommet for sheetmetal. You need to get the grommet onto the cable before trying to insert the grommet into the sheet metal.
Name:	speedo cable 65 Chevelle_20191013_0001.jpg
Old 10-13-2019, 03:51 PM
Default Thank Rich.
Thank you for the Pic. 👍
Old 10-13-2019, 04:05 PM
I ran mine over the engine/ transmission where the trans meets the bell housing & in the stock hole in the floor pan. I think I used on 8 inches longer than stock. I could get a pic if it would help.
Murf
Old 10-13-2019, 04:19 PM
Default Thanks Murf.
Yes please, pic worth is worth a thousand words.
Old 10-13-2019, 04:21 PM
Especially mine words!
Old 10-13-2019, 04:27 PM
Pics are from passenger side to drivers side.
Page 299 of Ames catalog. It gives the lengths so you can order for the year that wherever you like. I think I used 63.5 inch one but I’m not sure.
Good luck
Murf
Old 10-13-2019, 04:41 PM
One from under the hood. Cable is just above the adjustable prop valve knob. Hope some of this helps. It’s hard to get a good pic.
