Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-13-2019, 03:30 PM
ErikW's Avatar
ErikW ErikW is offline
Default KB Hypereutectic 455 HO pistons / .030 (Used)
Set of lightly used .030 over KB Hypereutectic pistons I took out of my wife's 455 HO motor. When used with the OE 197 HO head they produced 9.1:1 compression. They are in excellent condition and the specs are below. Includes pins and locks. (they can be press fit or full floating). Asking $150.00 plus shipping to US only. Thanks.
Erik
Bore (in):4.180 in.
Bore (mm):106.172mm
Piston Style:Dome, with two valve reliefs
Piston Material:Hypereutectic aluminum
Compression Height (in):1.500 in.
Dome Height (in):0.085 in.
Piston Head Volume (cc):0.00cc
Wrist Pin Style:Press-fit or floating
Pin Lock Rings Included:Yes
Wrist Pin Included:Yes
Pin Diameter (in):0.981 in.
Piston Ring Thickness:5/64 in. x 1/16 in. x 3/16 in.
ID:	522079   Click image for larger version
ID:	522080   Click image for larger version
ID:	522081   Click image for larger version
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 10-20-2019, 04:22 PM
ErikW's Avatar
TTT
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 10-20-2019, 08:30 PM
chiefbigb chiefbigb is offline
PM sent
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 10-26-2019, 11:44 AM
mikesauto mikesauto is offline
Default Pistons
I'll take them if they get to me
Old 10-27-2019, 03:28 PM
ErikW's Avatar
Sold!
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 10-27-2019, 03:42 PM
Default Pistons
