Old 10-13-2019, 06:41 PM
JLMounce JLMounce is offline
Default Compression test and plug change
It’s been about 4 years since I did the top end on the car. Lately I’ve been feeling as if the car has been a bit down on power. To an extent this has been backed up by a 1 to 1.5” loss in vacuum.
Decided I better start investigating. Warmed the car up to operating temp, pulled the plugs and ran a compression test.
Water temp was 170. Throttle wide open, fully charged battery.
Lowest cylinder was #1 at 172psi. Highest cylinder was #8 at 183 psi. If you look at my readings you’ll see the rear cylinders on each bank pump higher. This corresponds with a measured .002 tapper front to rear on the block. 1 and 2 are .007 in the hole while 7 and 8 are both .005 in the hole.
The plugs look okay but some of the ground straps are white which I’m not really liking. The #8 plug is too clean and I believe has not been firing.
Replaces the plugs with a hotter NGK br5ey.
Drive it a slight amount and gained almost an inch of vacuum, engine is smoother. Can’t really tell on power because even with possibly running on 7, it was still traction limited.
Thoughts?
ID:	522086   Click image for larger version
ID:	522087   Click image for larger version
-Jason
1969 Pontiac Firebird
Old 10-13-2019, 07:44 PM
shaker455's Avatar
shaker455 shaker455 is offline
Hit it with a few cans of seafoam
Carburetor building & modification services
Servicing the Pontiac community over 20 years
Old 10-13-2019, 08:12 PM
Funny you mention that. Lunati recommended that to me with their roller lifters. The car is about a month away from it’s pretty-winter oil change. I’ll probably run some through a bit before I change the oil.
-Jason
