Old 08-02-2016, 01:58 AM
brut4s's Avatar
brut4s brut4s is offline
Cool
  #102
Old 08-04-2016, 08:47 PM
pknopp pknopp is offline
Just because I said I would. Today was the first day in a long while I was able to work on the car. I needed a sand blaster and I was going to get a Harbor Freight. A friend of a friend said they had an Eastwood they used once for $100. I figured it had to be better than the H.F.
It was probably only used once.......but it was probably 20 some years old. The seal was like jelly. Would not seal. $45 for a new one? It's only a rubber ring. So anyway after some cleaning out of the old seal and some thinking I cut out a square out of an old inner tube. Cut a slit for the handle and slid it over. Tucked it in the top and it worked great.
Once I got it sorted it worked great........until it started raining........I got about 1/4 done. The pic just shows the crusty rusty frame blasted on the end and rain drops. I sealed what I did get done and hopefully will be able to get the rest ASAP.
  #103
Old 08-05-2016, 12:11 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
It might be a good time to replace the leaf spring bushings and the one in the frame mount. Mine were totally shot , I removed the rear mount to do mine . Looks good otherwise, I wish I could have blasted my frame clean
Illinois Outlaw Gassers
6.27@107
9.97@131
  #104
Old 08-05-2016, 12:48 PM
Yeah....I have them. The one is pretty well shot.
  #105
Old 11-02-2017, 09:42 PM
Been awhile.
ID:	466799   Click image for larger version
ID:	466800   Click image for larger version
  #106
Old 11-04-2017, 08:12 PM
A little more progress finally.
ID:	466892   Click image for larger version
  #107
Old 11-05-2017, 12:32 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Boy, I'll be glad when those frame rails get shortened. Make my knees hurt just looking at their pictures...
  #108
Old 11-05-2017, 12:34 PM
I hope to have that addressed this week.
  #109
Old 11-06-2017, 03:58 PM
mrrat1 mrrat1 is offline
I like it.....thanks for posting up the pics!!
  #110
Old 11-06-2017, 08:10 PM
Safari Larry's Avatar
Safari Larry Safari Larry is offline
Great to see some progress. Watching closely, interesting build, like it.
Larry Gorden
POCI 1956 Tech Adviser
www.PontiacSafari.com
  #111
Old 11-06-2017, 08:32 PM
Cleaned up the steering box today. Hope to have it back in tomorrow so we can figure out the headers on that side.
I was just thinking...........I kind of hate to do it BUT it looks like I will be cutting the wheelwells. In the long picture I am planning on welding in 55 Nomad panels but the wheel wells here are solid as can be. Someone may be interested for repair to theirs.
  #112
Old 03-20-2018, 09:51 PM
So.....still working. I hated to cut the quarters so I ordered a wheel with a 5 inch backspace. Fits great.
Decided to relocate the shocks above the spring so I wouldn't have to disconnect them to change the tire.
I did finally get the frame trimmed.
Got started on the headers.
  #113
Old 03-20-2018, 10:24 PM
Stuart's Avatar
Stuart Stuart is offline
Glad you were able to get wheels that fit without having to cut the wheel wells. It looks great.
  #114
Old 03-21-2018, 01:35 AM
Originally Posted by pknopp View Post
... I did finally get the frame trimmed...
Hurrah!!!
Glad to see you didn't want to cut the fenders. Did you need to mini-tub it? Were shorter rear shocks required with the moved lower mounting?
  #115
Old 03-21-2018, 12:28 PM
No tub. 9 inch slicks. 15X8 wheel with 5 inch backspace. I could probably get a 10 inch slick in there with no cutting.
The mount was actually moved up. I used the shocks I had on there to start with. The stock bracket pinched with the Mopar spring perches so we made new ones. (The guy I got the axle from had put the Mopar perches on the axle).
I had the springs re-arched and new pins put in.
  #116
Old 03-21-2018, 03:06 PM
Old 03-22-2018, 07:09 PM
Old 03-26-2018, 11:32 PM
Old 03-27-2018, 07:18 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
That looks awesome.
  #120
Old 03-28-2018, 02:57 AM
Thanks,
