Old 02-25-2024, 03:05 PM
KGTO's Avatar
KGTO KGTO is offline
Default Low speed only on wipers
I did search some, didn't find what I needed.
Sent non working wiper/washer to Steve Hackel who restored the unit, came back amazing. See pic. Installed and tested low, it worked. Then pushed for washer. Lines were dry but it shot water finally and great. Switched to high speed and it is the same speed. Tried washer again and nothing.
-If the motor only had one speed, will the washer still work? ( wondering if I have more than one issue)
Reached out to Steve, told me what I know already. #3 is grounded, or it's a bad switch assuming 12v at motor.
I disconnect the harness and applied 12v to #2 per the service manual. I jumped #1 and #3 to ground, low speed works. I removed #3 while #1 to ground and it's still low speed. Makes me think switch. But I test one more time, #1 and #3 connected, I apply 12v this time before I take the jumpered two terminals to ground and the wipers run (low speed) I remove #1 and the stop (no park).
As far as wiring, the motor leads can only go on one way, but the washer seems like it could be plugged in two different ways. Currently blu/wht is on left and black on right terminal.
Any help would be appreciated.
ID:	629331   Click image for larger version
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 02-27-2024, 03:28 AM
KGTO's Avatar
I guess I'm the only one in the community with this rare and unsolvable problem ��
1964 421 GP-Sold
Old 02-27-2024, 09:42 AM
johnta1 johnta1 is online now
Is this a depressed wiper or non depressed?
The #3 disconnected should have made the wiper fast.
The #3 circuit is probably grounded, whether internally at the wiper or at the switch. Look under the cover and make sure there isn't something hinky looking.
(the #3 circuit should be open for hi-speed)
Also should be a resistor there that needs to be good.
Old 02-27-2024, 07:40 PM
KGTO's Avatar
Hi John, thanks for the reply.
You mean recessed park? Yes it is.
I can pull wiper cover put I'd hope after being restored nothing is "hinky" haha...
Where is the resistor?inside the wiper motor? If I remove the switch couldn't I check continuity on each terminal to ground? Since I understand power is always at the motor/washer and ground is applied to make the circuit, seems like I could rule out the switch that way.
1964 421 GP-Sold
Old 02-28-2024, 07:26 AM
Under terminal connectors, under a cover probably.
Old 03-17-2024, 04:19 PM
I also had Steve restore my wiper/washer. Mine works as it should. Not sure about washer. I never checked it, because I'll never use it. I left my fluid bottle dry. My car stays clean.
