Old 10-10-2020, 09:27 AM
cnc's Avatar
cnc cnc is offline
Default 73 redo
Well time has come for paint finally for my car...
I’ve started stripping and gutting the shell to basically nothing.Engine , trans, dash ,heaterbox, complete interior etc....
In the process now of taking the paint off
I’m also going to rescure the under hood bracing to the skin with the 3M NVH product recommend here from mrennie as well as others
Stripping the paint is tough not sure if it’s had hi build primer under it but it seems thick too.....I’ll post some pics if when I remember kinda get caught up in the process....
No filler to be found and still has the lead on the quarters It looks like
ID:	551150   Click image for larger version
ID:	551151   Click image for larger version
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
The Following User Says Thank You to cnc For This Useful Post:
Old 10-10-2020, 11:19 AM
ZeGermanHam's Avatar
Those quarter panels without any damage or body filler are a beautiful sight! Congrats.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 10-10-2020, 04:30 PM
cnc's Avatar
cnc cnc is offline
Just spent three hours or so cleaning my hood for the NVH foam filler .@$90...this is what happened and not realizing what was going on until it started coming out the back of the cartridge ....uneventful day to say the least,,,,I got some stuff in the there and will see what happens but doesn't look promising..it was wayyyyyy runnny but was still black in color....
Old 10-10-2020, 04:35 PM
cnc's Avatar
cnc cnc is offline
Thanks yes quit happy HOPE to not find any surpeises.....anywhere ..
Old 10-10-2020, 07:00 PM
JUDGE3 JUDGE3 is offline
curious to see how the nvh foam works out. hadn't heard of it. I see it has a 60 min work time so it must be pretty thin. read that its used between panels prior to installing a panel so sounds thin? I would like to put extra support "blobs" between the hood skin bracing as well.
I'm thinking the flexible 3m seam sealer in black will work. I used it quite a bit. expensive but really hardens yet flexible. not runny either.
I shouldn't admit this but did something very silly. on my 69 Gto hood I had this idea that black roofing caulk would simulate the blobs and be flexible and work great. I squeezed some out and it seemed perfect and i figured being for roofs would be heat tolerant.
after driving it the next day, luckily by chance I popped the hood for a maintenance check, well the roof caulking was dripping down all over the place! boy that was a bummer cleaning all that. I was cheeping out thinking I outsmarted things.
Old 10-10-2020, 11:08 PM
cnc's Avatar
cnc cnc is offline
The NVH didn’t work out for me I’ll know better tomorrow but .... not happy...
Old 10-10-2020, 11:32 PM
cnc's Avatar
cnc cnc is offline
Trunk drop offs as well left and right side
ID:	551205   Click image for larger version
Old 10-11-2020, 09:29 AM
mrennie's Avatar
mrennie mrennie is offline
When I used that product, by the time it came out of the zig-zag mixing tip is was black but had a rough looking texture, if that makes any sense. If it had not mixed with the activator it would probably look smooth.
I think if the 2 parts mixed enough it should still set up, eventually...
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 10-11-2020, 01:28 PM
Let us hope for the best, but based on the photo posted above, it looks like only one part of the 2-part mix came through the gun. Eeeps!
Old 10-11-2020, 06:23 PM
cnc's Avatar
cnc cnc is offline
Well loooked at the hood this morning and yes some of the stuff mixed and has the rough looking texture kinda reminds me of Eatmore Chocolate bar with out the peanuts...lol
Other is smooth but looks like it might have held....I'll check again tomorrow
I bought it from amazon and emailed the company I got it from told them what Happend ...see if anything happens don't expect anything
So either I leave it or look for it locally and redo it all...
Old 10-11-2020, 09:21 PM
mrennie's Avatar
That stuff isn't cheap, hope you get some satisfaction.
Michael
Old 10-11-2020, 09:31 PM
cnc's Avatar
cnc cnc is offline
Well I did get a reply back it's from Browns auto supply in Chatham they are the seller
He wanted a pic of the tube the gun and the receipt...I Replied to him which is somehow through Amazon and it came back pic to big ...etc
Sooooo
I contacted Browns in Chatham just now with an email to contact The gentleman I was contacted by....will see what happens they offered full refund or another tube...see what happens...
Old 10-11-2020, 09:45 PM
cnc's Avatar
cnc cnc is offline
Today I stripped out the trunk lid top and bottom the trunk channel and surround
Also stripped the tail panel ....all with no suprises...
Tomorrow I'll do the pass side door hinges ...ordered a kit online from a place in Sarnia short shipped two bushings sent them an email got a Call from them that nite ....they send me to there returns line leave a message ....that was a week ago ....crickets .....went out and bought bushing kit...last one from part source....counter guy was shocked he had it....
Once the bushings are in I'll strip the doors and the jambs..not gonna worry about the roof area to strip where the rubber seals fit and the chrome decor moldings attach to...I don't think...I'll look at it all tomorrow again...
Another note .....Krylon Semi flat black paint in an aerosol ...non to be had around here...
Home Depot,Rona , TSC,Homehardware,Canadian tire .....nothing ....so ordered it online from Grainger 5 cans $50 shipped to my door next couple days should Have them...need to paint up the inner fenders and heater box....apparently this is very close to factory ....
Pics tomorrow.....get caught up in the moment and forget pics...
Never mentioned this at the beginning but I'm only stripping the car down I'm shipping It off for prep and paint...hoping for the end result to be painted Navajo Orange with the 71-72 stripe kit.....and rear spoiler add on....similar to pic attached
Old 10-12-2020, 06:38 PM
cnc's Avatar
cnc cnc is offline
Well did the trunk adjustment today best possible it's kinda wide at the top on the pass side but if I move it to take up the gap on the upper right the lower left get too tight for my liking...I can live with it....it better than it was before
Found my first sign of filler drivers door no big dents just some small stuff...
Also cleaned the jambs up and then I'll do the doors..but not doing all of it just wanna do the outer area of the door up to the seal area ...
I also did the door pins in the pass door today...pain in the arse to do cause I couldn't get the door open enough to get the upper hinge out..so I had to loosen the lower hinge and finagal it out then adjust the door...
So I've got the hood to do...both fenders lower Valance and tail filler panel
...oh and the rear spoiler so think I'm doing ok for end of November ....
ID:	551312   Click image for larger version
ID:	551313   Click image for larger version
ID:	551314   Click image for larger version
ID:	551315   Click image for larger version
Old 10-17-2020, 03:40 PM
cnc's Avatar
cnc cnc is offline
So never heard back from Browns....he never forgot my pics and I never got another email...so done with them
I can get the stuff through Wurth at work actually cheaper thank Browns...anyway I’ll order that Monday.
Today stripped out the fender delivers side found filler in the frt of it minimal again.....
Need to get an adapter for my sandblaster I have so I can do the inner section of the fender that rests against the inner fender...
Pass side fender is stripped out as well no filler at all
I got some Rustoleum semi flat black ...painted both inner fenders engine side only thus far ...I’ll don’t he iwheel well side tomorrow...and the heater box.....happy with the result I bought 5 cans
I’m gonna do the subframe and firewall when I get the car back ....I don’t want a start spraying water and grease All over the place ...
ID:	551632   Click image for larger version
ID:	551633   Click image for larger version
Old 10-21-2020, 06:52 PM
cnc's Avatar
cnc cnc is offline
So I got nowhere with the 3m stuff and never heard back so I moved on...
We work with and deal with Wurth at work...talked to our rep and he is a Collison certified tech and has done a lot of panel bonding previous to the sales area...chatted with him for a while and told him about the stuff I got from 3m and what I was using it for and he suggested this expanding foam it's also used for x bracing in hoods trunks door etc...
So he brought me a tube to try ...well gotta say I like the results ...I may have been a little to liberal with it but I like the results....I'll see if I can do Any type of re forming some on a test piece ....
Anyway thought I'd post some pics...
ID:	551968   Click image for larger version
Old 10-26-2022, 07:49 PM
cnc's Avatar
cnc cnc is offline
Ok so after a long layoff due to Covid and shipping and parts pickup from people I send stuf to in Michigan I've been back at it...
Car has been sent out for paint and it's home that was 2 years ago....
I've got new carpet, under layment, door seals, trunk seal, hood seal, interior paint mixed to match best possible ...
Unerhood was painted
I've put the engine back in, transmission and new lines re routed aux cooler
Disassembled the dash tonight to take it to work and clean clean clean to get ready for paint...
ID:	601146   Click image for larger version
ID:	601148   Click image for larger version
ID:	601153   Click image for larger version
Old 10-26-2022, 08:06 PM
cnc's Avatar
cnc cnc is offline
Some more pics. New aftermarket birds from PY cleaned the Script best possible, painted taillight housings cleaned lenses bezels ....Geez can someone flip these or tell me how to???
ID:	601162   Click image for larger version
ID:	601163   Click image for larger version
ID:	601164   Click image for larger version
ID:	601165   Click image for larger version
Old 10-26-2022, 08:11 PM
cnc's Avatar
cnc cnc is offline
Couple more....
ID:	601168   Click image for larger version
Old 10-27-2022, 11:59 AM
Open the pic on your computer, crop it just slightly, then save it - then upload it...another member here saved me once
It resets the photo cuz the site is picky.
