Old 07-16-2005, 01:16 PM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
The paint job on my 68 GTO is about done.
I need to know the measurements to install the white GTO decals on the rear fender in front of the emblem.
Thanks,
Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Old 07-18-2005, 03:48 PM
Brew Brew is offline
I just eyeballed mine.
67 LeMans vert w/462
68 GTO bone stock
Old 07-18-2005, 05:14 PM
Verdoro 68's Avatar
Same here. I tried to center it up visually on the arrowhead marker and quarter panel, but I didn't do any precise measurements.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 07-20-2005, 10:23 PM
cuz68's Avatar
cuz68 cuz68 is offline
I did the it the same way as you did Ken, I have not asked this ? But i put black ones on mine, Did all of them come with the white ones?
Cuz68
Old 07-20-2005, 10:52 PM
Verdoro 68's Avatar
It depends on the color combination of your car. For Verdoro Green all you could get was white, regardless of interior color. For a red car with a black interior you got a black decal, with a red or white interior you got a white decal. Same goes for the pinstripes aka rally stripes. Below is the chart from the resto guide.
Ken
Old 07-21-2005, 08:12 AM
newtoGTO newtoGTO is offline
I'll try to figure out a way to measure mine and send the measurements. One side of my car is original.
John
Old 07-21-2005, 08:42 AM
Gus_Mahn Gus_Mahn is offline
Greg Reid posted a link below "68 owners may enjoy this". There is a picture of this decal in the article from 1968.
Old 07-23-2005, 07:07 PM
cuz68's Avatar
Thank you ken. Very good info as aways.
Cuz68
Old 07-25-2005, 08:20 AM
Half-Inch Stud's Avatar
I enjoy the Trim chart. Owned a 68GTO trim code "N", and now " A ". HIS
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 07-26-2005, 04:22 PM
sedan_dad sedan_dad is offline
This is from Motor Trends story on the 68 winning it's car of the year award.
I think this would make a good reference as to placement of the decal.
There is no such thing as a mistake- only more welding.
Old 09-28-2020, 09:43 PM
brjgto brjgto is offline
I measured mine before a paint job in 1980. Original decal on the rear fender was forward of the arrowhead centerline to the front of the decal 10.75" The height of the top of the decal was just below the top first letter on the arrowhead. Of course level is most important. use a long tape mark from the arrowhead forward to front fender parallel to the bottom of the sill.
Old 09-29-2020, 10:33 AM
gtohunter's Avatar
gtohunter gtohunter is offline
Just eyeballed mine as well...
Jimmy M
68 GTO
Old 09-30-2020, 01:20 AM
PurelyGTO68 PurelyGTO68 is offline
Looks good. Pretty sure they were eyeballed at the factory also. I have seem lots of factory literature with a variety of different placement. High, low, etc.
Old 09-30-2020, 02:17 AM
If you look at enough photos from the 1968 era you'll see that there was definitely some variance in the placement from the very beginning. If you make it horizontally straight with the marker lamp as a reference and place it very slightly above center and 'about' one half of one letter's width from that marker, you'll be good.
Here's where I put mine and I didn't sweat about it too long when I placed it. Just used the old TLAR method..ie, 'That looks about right'...
Old 09-30-2020, 04:51 PM
citrusz citrusz is offline
Perhaps these will help. Pictures of my original 68 GTO before the restoration.
Name:	GTO More 010.jpg
ID:	550640   Click image for larger version
Name:	GTO More 011.jpg
ID:	550641   Click image for larger version
Name:	GTO More 012.jpg
ID:	550642   Click image for larger version
Name:	GTO More 014.jpg
Old 10-13-2020, 01:07 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
Not sure why this thread was brought up but glad it was, I would say the answer depends on the build date and or assembly plant. The early sales literature I have seen shows the decal being at the top of the marker light, similar to what's emulated on the two early Kansas cars. Perhaps the original design placed it at the top of the marker light and then at some point later changed to be more marker light centered.
I find it hard to believe that it would be left to the plant to decide the placement of the decal in the original design of the 68 GTO. Although there could have been a directive to change the location, centered more on the marker light, which may have led to a plant aspect. I find it even harder to believe that it would be left to workers on the line to decide where it was going to be placed on any particular day.
That's not to say there were not exceptions I'm sure, but in most cases I would think there was a proper method for location, using a template. As "dataway" said, "his looks low" and is the exception, it appears that the decal was placed under the stencil line instead of above it. If a decal were to be applied right above the one on his car it would likely be in the correct location, to me it's not a haphazard application, just a mistake.
It would make more sense if a design change had occurred and a plant aspect was involved, rather than the comments of indiscriminate placement. I realize there are 'slight' variations as "Greg Reid" mentions, but there is also two distinct locations, that's my point, a early/late location, or plant variation. I am still looking to find more early original examples like the two Kansas built cars shown, if I remember correctly the other cars posted here are all later builds.
Also notice the two Kansas Verdoro cars, one with White, one with Black, contrary to the trim chart posted which lists only White for Verdoro. Is this another case with the early cars? Doesn't seem it would be a plant specific thing, please post if you have a uncommon combination, thank you in advance. Anyone who can share info of their car I posted and also anyone with images of their original decal location would be greatly appreciated, again thanks in advance. There was a prior discussion on this but I would like to see a more definitive answer for us all. Link- http://forums.maxperformanceinc.com/...d.php?t=420170
My car, Build date 11-B-67, Kansas, color Verdoro.
Member-"68gtoMN" Build date 10-67, Kansas, color Verdoro.
Member-"OG68" Build date?, Fremont.
Member-"J GLASGO" Build date?, Plant? 20,000 mile Original.
Member-"68gtoMN" Build date 03-C-68, Pontiac.
Member-"dataway" Build date?, Arlington.
Member-"Greg Reid" Build date?, Plant?
Member-"joe'sgto" Build date?, Plant?
Early sales literature.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 10-13-2020, 10:25 AM
OG68 OG68 is offline
Build Date 5-A-68 for the Solar Red Fremont car
2007 Cadillac SRX
Old 10-14-2020, 01:48 AM
I have no idea on the build date of my old Mayfair Maize car. Owned it back in the early 80s and I have nothing left from it.
Old 10-14-2020, 10:25 AM
Keith Seymore's Avatar
Correct - it would not have been left to the assembly location or the operator; after negotiation between product engineering and marketing the location would have been defined and should appear in the Product Assembly Documents ("PAD" sheets, also known as "PDM" - Product Description Manual).
Also correct - a fixture would have been designed and provided. However, that doesn't necessarily mean that the operator is going to use it every time. The bigger and bulkier the fixture the less likely he/she is to use it, and it is also dependent on whether the boss is looking and the operator's attitude in general.
Lastly, I have to mention (as I always do when this topic comes up) - our stickers washed off our brand new '68 the first time we took it through an automated car wash. Dad left them off at that point.
Sidebar for a funny story:
When we got our '68 GTO - new in 1968 - those decals washed off the first time we went through an automated car wash.
It was one of those where you get out of the car and the worker takes it through. After it had gone through they pulled the car way off to the side, and a bunch of people gathered around it.
Dad thought "WTH" and started walking over there to see what was going on. The guy that owned the car wash met him part way and said "...uh, Mr Seymore....uh - we have a problem. It seems those little decals on the back came off in the car wash".
Dad looked at the car for a second and said "Good. Now I don't have to figure out how to get them off there".
Name:	68 GTO Silver.JPG
ID:	551392   Click image for larger version
Name:	68 GTO Lapeer.JPG
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 10-14-2020, 10:28 AM
Found another thread that digresses into this topic:
http://forums.maxperformanceinc.com/...ight=automated
'63 Grand Prix
