Old 11-02-2018, 12:11 AM
tharkun8 tharkun8 is offline
Originally Posted by Lee View Post
I talked with Britt. It was too long ago, and he doesn't remember the details other than what is above.
Lee,
thanks for trying to help. I understand this thread is so old that it was a long
shot.. I just figured there has to be someone on this board that can point
me in the right direction.
I can understand that this isnt the most common swap .. but I figured someone
on this board has done it before/ knows what needs to be done and it sounds
like Goat has a working example.
Im getting to be an ok wrencher but custom fabbing.. (esp motor mounting)
is something I dont feel comfortable trying.. If I can just see some pics of
a good existing setup then I can probably take it and run with it..
Thanks again
John
Not all who wander are lost...
1964 Starchief 4 Dr Sedan - 389 4Bbl - Auto - Pinehurst Green/ Gold cloth
1964 Grand Prix - 389 4 BBl w SupHyd auto
1964 Catalina Safari - 63 389 200r4 auto.. 2.69 POSI rear
1964 Bonneville Vert - 389 4bbl - Auto - Ext Color - Saddle/Saddle int
1965 2+2 - WG 421 4Bbl - 4 spd - Bluemist Slate w White/black int
1966 Ventura 4 dr Sdn - 389 4Bbl - Auto -Orig Color - Barrier Blue
Old 08-10-2021, 10:00 PM
83pontirado 83pontirado is offline
Try moving the engine 2 inches fwd that should fix the linkage problem, my problem is i have no clue on how to mount the 67 400/TH400 combo that came from a catalina into the my 83 Silverado (hence my user name "83Pontirado&#129315 i know this is an old thread but maybe some one with better knowladge could help me out.
Old 11-10-2021, 09:33 AM
jandvloar jandvloar is offline
you need the frame mounts and pads for a 1970 firebird.
or what I used in my 78 firebird to mount older engine is a set of 2 bolt to 3 bolt mount adapter brackets. that should let you use the chevy clam shell frame pads. you will still probably have to move them since if I remember correctly the pontiac mounts are slightly forward of the chevys and one is a little more forward than the other.
simply bolt everything to the engine with whatever setup you choose set it in place, mark the bolt holes and pull it out to drill.
All modern gms use the same mounting angles at the frame and fan centerline.
Old 11-10-2021, 09:31 PM
I found the whole mount kit for the older engine to fit the clam mounts through butler performance. Im going to try and post the screen shot because i do believe it has the part number also
