OHC-6 TECH Over Head Cam projects, questions and advice.
Old 07-27-2020, 08:41 PM
Mike Davis's Avatar
Default Value of OHC6 4bbl
I have not followed the OHC stuff in a long time. I have in possession a 1966 OHC6 4bbl engine that came out of a 66 Lemans. It is complete from air Cleaner to oil pan, correct carb, starter, pulleys, fan etc.
It has had an older rebuild and runs but has not been started in about 10 years but turns over.
Thinking of selling if I can't find something to put it in-
What would be a ball park figure for this?
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 07-28-2020, 06:50 AM
Jeff Hamlin's Avatar
Default PRICES ALL OVER THE MAP
There are approximately 12 full engines available online.
Both on EPAY and Private online sales.
Everything from fully machined running for $6000
to $900 unknown junk down to $200 known runners.
If yours has all the correct bolt-on bits and can be verified as a good internal engine it IMO has better value then most.
1200 is where I would start but this is just my opinion.
Selling full engines and/or long blocks has never been easy. I always end up parting them out.
I wish you were closer I'm slowly building a '66 4BC engine and always interested.
Old 07-28-2020, 08:31 AM
mysticmissle's Avatar
i would say in that range. I have a 6cyl 1 barel going for 1200 complete carb to crank. yours has to be worth that or more especially with carb and air cleaner, in my opinion
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 07-28-2020, 08:53 AM
Mike Davis's Avatar
Thanks for the replies. Not sure what I will do yet. I was thinking around those numbers.
Thanks again.
