OHC-6 TECH Over Head Cam projects, questions and advice.
Old 08-08-2020, 10:00 AM
Doctor john Doctor john is offline
Default Oil pump cover leak
I have a leak at the oil pump cover. I have a new gasket on order. Should I use sealant to prevent future leaks? If so which one?
Old 08-08-2020, 05:35 PM
694.1 694.1 is offline
Not likely the cover. Could be a bolt head though?
In my experience, it is the oil pressure sending unit or the fuel pump "vent".
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 08-08-2020, 08:26 PM
Hokie1984 Hokie1984 is offline
Had the same issue recently. I used a light coat of RTV after taking a file to the oil pump to remove any high spot.
