Old 09-30-2020, 06:38 PM
Dick Boneske's Avatar
Default 1960 Tripower Thermostat Housing Gasket & Vacuum Fitting
I need three thermostat housing gaskets for 1960 Pontiac Tripower. This is the only year where Tripower thermostat housings had an extra outlet for the heater hose.
Also, for the TEE fitting in the base of the center carb, there is a 1/8" steel tube that provides vacuum for the heater or heater/AC. I need some of the brass fittings that secure this tube to the TEE. The threads are 5/16-24. The fitting is bade of brass. Note the picture.
ID:	550651   Click image for larger version
ID:	550652   Click image for larger version
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 10-01-2020, 10:35 AM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Hi Dick! Did you try www.pontiactripower.com ?
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 10-01-2020, 11:53 AM
No, but I'll call John Wright. Thanks.
BONESTOCK GOATS
