Old 10-19-2020, 02:00 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
Default 62 Convert. Carpet.
. Was going to order carpet for my 62 Convertible. Ames shows the carpets discontinued. Can I get recommendations from you guys. Good luck or bad product. Thanks.
Old 10-22-2020, 07:18 AM
Jeff Hamlin's Avatar
AUTO CARPET DIRECT, LIST '62 HT
but says will not fit Conv't?
Wouldn't HT carpet be wider?
I used them for my '66 and I'm very pleased with their carpets.
Old 10-22-2020, 08:40 AM
Radman's Avatar
Radman Radman is offline
Yes the hard top is wider in the rear seat area. You can use the hard top, but will need to use a heat gun, or hair dryer to reform the floor well depression. Also it is best to trim some of the excess carpet from each side. Start in the center and work your way out. Or open your wallet and let an upholstery shop do it.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 10-22-2020, 12:43 PM
Thanks guys.. SMS Auto Fabrics makes carpet for the convertible. Ain't cheep. I ask a carpet guy on e bay and he gave me the their name.
Old 10-22-2020, 02:09 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Kanter sells carpet too, not sure of the quality but not to bad of price.
Old 10-22-2020, 02:46 PM
Stuart's Avatar
Stuart Stuart is offline
I'd call ACC and talk to them, just because their website says hardtop only doesn't necessarily mean they don't have patterns for a convertible. If they don't, they may be able to use your existing carpet as a pattern - they did that for me and my '61 Bonneville.
Old 10-22-2020, 07:27 PM
Ordered from SMS. Thanks for the answers.
Old 10-23-2020, 06:50 AM
Default CORRECTION
I know you're all set but FWIW I knew something didn't seem right with my post.
It wasn't ACD it was ACC I dealt with.
Their eBay store offered the carpet set for less than their website.
I requested a few samples as I didn't like the "Correct" color and they had.
Customer service and delivery were flawless.
Fit and Finish are perfect!
