Do these measurements come with the stripe kits from PY?
ET 13.2 and spinning like a mother
ET 12.504 MPH 107 3940 lbs |
Darrell, let me know if you need a bigger picture. Or sell me your exhaust manifolds and I'll give you a copy and the air conditioning part.
So long, farewell. |
You had better hurry 3 hours left on the auction. I would like to help you but I need the money for a set of Dougs headers.
Were did you get that picture? ET 13.2 and spinning like a mother
The manifolds are overpriced as of now, $455 and change. The picture came with NOS Judge stripes or decals. I will be at the yard today and look for that A/C suitcase part.
Sorry Ransom, I cant believe someone paid that!!
Do you ever think you can make rock falls raceway this summer? Its between Eauclaire and Menomonie. ET 13.2 and spinning like a mother
Not with any of my cars this year. There should be a gold and/or a black '70 GTO that will be needing track time this year though, so I will be there. I had a '73 red TA that has been there before, as well as an old '69 convert. Firebird.
There is also a picture of the measurements in the 1970 LEMANS/GTO & GRAND PRIX ASSEMBLY MANUAL page 525.
This photo is from HPP 6/2000.
With the front stripe, start at the door, leaving a enough to wrap inside the door, the rest of the placement takes care of itself. As you see in the photo, the bottom of the stripe just follows the body line, although it is a bit above the line, not on it. Look at the photo and you will see the stripe is a little higher than the body line. On the back, I just centered the stripe between the front of the quarter, next to the door, and the back edge, before the bumper. I looked at all the pictures I could find, and it appears centering it this way is correct. Again, the '70 has such a sharp body line here, it's easy to follow with it with the stripe. |
Front to back - I centered the rear stripe on the quarter.
****Come on Ransom Please please send me those specs.
Thanks slow gto now I could use the placement of the "Judge" emblems
