Old 05-23-2024, 04:36 PM
Tim Corcoran's Avatar
Default Who Makes Headers for Pontiac ?
Besides Doug's who makes quality headers for 65 A body
Tim Corcoran
Old 05-23-2024, 05:18 PM
65madgoat's Avatar
Hooker Super Competition
But I would go stainless with new Doug's:
https://butlerperformance.com/i-3164...tegory:1459705
Or ARH has stainless for twice the price that are sick
Old 05-23-2024, 05:30 PM
1968GTO421's Avatar
There used to be lot for Pontiac V8's. Here are a few still extant.
Doug's
Hedman
Flow-Tech
Summit
Jegs
Hope this helps!
GTOAA--https://www.gtoaa.org/
Old 05-23-2024, 06:06 PM
I need round port 1-7/8 and don't want to use a tiny filter like with Dougs
Tim Corcoran
Old 05-23-2024, 06:28 PM
https://forums.maxperformanceinc.com...d.php?t=468168
For zero dollars invested you can more than likely get enough clearance to run the Doug’s headers with a normal sized filter. Doug’s are superior to the other brands when it comes to ground clearance and fit.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 05-23-2024, 08:51 PM
indymanjoe's Avatar
X's 2 ^^^
Old 05-23-2024, 09:39 PM
Does anyone know if these ceramic coated headers are coated on the inside too or just the outside. If they are only coated on the outside they can still rust from the inside out. I have a set of Indian Adventures 1-7/8 headers that I really like and I have Flowmaster merge collectors on them too. They are in decent shape but rusted some on the inside. I'm trying to decide if I should have mine coated or buy new ones already coated.
https://butlerperformance.com/i-2445...tegory:1459705
Tim Corcoran
Old 05-23-2024, 10:05 PM
Dragncar Dragncar is offline
Mad Dog is still making fine Pontiac headers.
He did some work for me recently.
Old 05-23-2024, 10:25 PM
Mad Dog makes some very nice headers. I bought a set several years ago for my 65 LeMans and they did not fit. Even after denting the crap out of them they just wouldn't fit. I think it may have been partly because of the frame sagging. Anyhow I sent them back and he gave me a full refund. I was disappointed because they were very nice stainless headers.
Tim Corcoran
Old 05-23-2024, 10:49 PM
indymanjoe's Avatar
Dougs are coated on the outside afaik. my 14 yr old dougs look great even where i scrapped them through the years taking them off etc.. i just bought a set of the round port head version and they do look, coating wise, the same as my old set.
Old 05-24-2024, 05:41 AM
64speed's Avatar
64speed 64speed is offline
I run a regular filter with my Doug’s.
Old 05-24-2024, 03:34 PM
Hedman used to make a nice set of tri-y headers for 1961-1964 big Pontiacs. Too bad they still didn't.
Old 05-24-2024, 04:09 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have some new IA multi piece round ports for early A bodies.
Skip Fix
Old 05-24-2024, 05:09 PM
Those ARH headers are VERY nice. I have a little more than that in my Mad Dogs and they are mild steel 18 ga.
I bought 480$ merge collectors for them, and had them coated inside and out.
The ARH headers already have the merge collectors (worth significant torque) and are SS.
And my Mad Dogs have the rear tubes on both sides go out the fender well and around the frame !
Looks like the rear tubes all stay inside on the ARH headers.
Mine are probably a little bigger inside dia being 18 ga.
But those things are NICE and worth the 2K.
Old 05-24-2024, 05:54 PM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
I kick myself every time I that think that I sold my Mad Dog headers!🤬 All the ground clearance in the world, and such breeze to install or remove!
Old 05-24-2024, 06:46 PM
Skip Fix's Avatar
There was a thread a year or so ago about a guy fitting the cheap SS OBX brands on an early A body . Had to tweak a tube or two esp around stick Z bar.
http://forums.maxperformanceinc.com/...ht=OBX+headers
Skip Fix
Old 05-25-2024, 12:18 AM
turbo69bird's Avatar
For a company that has been making Pontiac headers forever ! And made them for many other company’s as a wholesaler. Go to Tubular automotive.
They made them for many major brands These were the original headers on my RAIV car back when Stephen Pontiac raced it. Great guys great prices.
Also mad dog made me some nice headers both great choices.
They were RAV also. Had one interference spot but the 5 ina bird is a tough header. Especially w really big tubes.
960 HP @ 11 psi, 9.70 at 146.
Old 05-25-2024, 08:18 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I would highly doubt any coated headers are coated on the inside. BTW, those are Doug’s on Butlers website.
Old 05-25-2024, 08:20 AM
ponchjoe's Avatar
I would highly doubt any coated headers are coated on the inside. BTW, those are Doug’s on Butlers website in case you didn’t know.
Old 05-25-2024, 09:43 AM
Gary H's Avatar
Gary H Gary H is offline
You can run a full size filter with Doug's headers. The filter will go on with no problem on an automatic equipped car, but on a manual transmission car you will need to clearance the bellhousing ear on the passenger side and the filter will then go in.
