Old 03-27-2024, 09:40 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default New ‘69 Judge
Cool photos of the purchase of a 1969 Judge.
Curious why the RH Judge decal is crooked, whereas the LH looks much better.
Very cool day one photos.
ID:	631173   Click image for larger version
ID:	631174   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
The Following 3 Users Say Thank You to 60sstuff For This Useful Post:
Old 03-27-2024, 05:54 PM
thepontiacman's Avatar
Cool to see that.
Did it say what dealership?
Thanks for sharing.
The Following User Says Thank You to thepontiacman For This Useful Post:
Old 03-27-2024, 08:36 PM
4dblnkldude's Avatar
Super cool!
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 03-27-2024, 09:53 PM
60sstuff's Avatar
Originally Posted by thepontiacman View Post
Cool to see that.
Thanks for sharing.
No dealership name but it looks to be Illinois plates.
Old 03-28-2024, 01:03 AM
242177P's Avatar
242177P 242177P is offline
Looks like someone is explaining Ram Air to his son (younger brother?)
The Following User Says Thank You to 242177P For This Useful Post:
Old 03-28-2024, 08:38 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Awesome pics!!!! Can't imagine how cool that is
Chris D
Old 03-28-2024, 10:17 AM
Keith Seymore's Avatar
Keith Seymore Keith Seymore is online now
I figured there must be measurements called out in the assembly manual - and I was right.
I would imagine (rather than measuring it out on every vehicle) they had some kind of fixture or template to help locate the decal. The only problem with that is they typically are clunky and slow you down, so they fall into disuse as soon as management is not looking. The guy eyeballs it and this is what you get.
These days we build some locating features into the premask to help place the part. Remove the premask and the graphic should be in the right spot. The tradeoff is the more extra material you add the bigger the part gets and the more it costs.
Also - probably a different guy putting the LH side on vs the RH side.
K
Name:	Judge decal placement 69.JPG
ID:	631247   Click image for larger version
Name:	Judge graphic 1.JPG
ID:	631248   Click image for larger version
Name:	Judge graphic 2.JPG
ID:	631249   Click image for larger version
Name:	Judge graphic 3.JPG
'63 LeMans Convertible
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 03-28-2024, 03:51 PM
GordonGeesey GordonGeesey is offline
Interesting that the RH headlight cover seems to be properly lined up in one photo, but then askew in another photo. Wonder if they were playing with the lights with the engine off and ran the vacuum canister down to empty?
