Old 10-29-2018, 06:46 PM
Jeff Hamlin's Avatar
Thumbs up
Steve,
That is from the 1966 DELUXE Dealer Brochure.
The Lemans and the GTO both are depicted with 8-Lugs
GM was really hoping to get the 8-Lugs onto the A-Body platform but it was just to costly and as we all know never came to be.
  #42
Old 10-30-2018, 04:52 PM
stevep's Avatar
stevep stevep is offline
Originally Posted by Jeff Hamlin View Post
Steve,
There is a 1966 PMD promotional video showing all off the different cars and a 66 Lemans pulls up with 8 lugs on it.
  #43
Old 10-30-2018, 07:02 PM
Thumbs up
It's the GTO. Wide Open World of Youth 1966.
Sorry for derailing this topic.
  #44
Old 10-31-2018, 06:21 PM
stevep's Avatar
I would have bet that it was a Lemans
  #45
Old 11-01-2018, 12:29 PM
shaker455's Avatar
shaker455 shaker455 is offline
Update:
Added 50/50 mix to cylinders and going to try to make it move over the weekend.
Carburetor building & modification services
Servicing the Pontiac community over 20 years
  #46
Old 11-01-2018, 07:27 PM
stevep's Avatar
Default Awesome!
Originally Posted by shaker455 View Post
Update:
I'm looking forward to your post with the engine running.
  #47
Old 11-02-2018, 07:57 AM
shaker455's Avatar
I need a steering wheel
the plastic is cracked and 1/3 has fallen off exposing the chrome steel ring that makes up the wheel.
I found a tilt column in the trunk but not changing at this point.
I also found one of it's fender skirts
If motor proves to be too stuck I'll pull it out for the winter, break it down and give it what it needs.
I want to drive it daily next spring.
  #48
Old 11-02-2018, 09:29 PM
stevep's Avatar
I have the wipers and I should have a skirt.
  #49
Old 11-03-2018, 05:33 AM
shaker455's Avatar
I found a few sheet metal pieces locally.
I take it the Bonnie & Catalina shared sheetmetal?
  #50
Old 11-03-2018, 08:22 AM
Stuart's Avatar
Stuart Stuart is offline
They'll share some sheetmetal...assuming you're talking about two door hardtops, the front clip and doors will be the same, other than maybe some trim holes. From there back a Bonneville has a longer wheelbase so the rear quarters will be different. Not sure about the trunk lid or the rear panel between the taillights. Bumpers are the same.
  #51
Old 11-03-2018, 08:37 AM
shaker455's Avatar
I'm sure my rear quarters will need something so I will need a source?
  #52
Old 11-03-2018, 11:46 AM
77 TRASHCAN's Avatar
Who knows, even if you get the crank to turn, it might still need to come out.....I am like your neighbor Wayne Carrini looking for a cool car, I like to see what's inside an ancient engine!!!
Shut it off
Shut it off
  #53
Old 11-03-2018, 11:48 AM
shaker455's Avatar
Haha! I'm thinking the same thing.
I'm sure it could use some TLC and new seals along with some engine paint.
  #54
Old 11-03-2018, 01:27 PM
Stuart's Avatar
If you just need patch panels you may be able to adapt sections from a Bonneville rear quarter, but check the contours first.
  #55
Old 11-03-2018, 06:55 PM
stevep's Avatar
Bonneville rear 1/4 panels are longer than Catalina/GP.
  #56
Old 11-05-2018, 10:47 AM
shaker455's Avatar
This poor car has seen enough outdoor action/ neglect.
  #57
Old 11-05-2018, 07:44 PM
stevep's Avatar
Is the engine spinning over?
  #58
Old 11-06-2018, 01:15 PM
shaker455's Avatar
Not yet Steve,
You know anyone selling a Edelbrock P4B
An early one that has both bolt patterns?
  #59
Old 11-06-2018, 09:00 PM
stevep's Avatar
Not offhand.
  #60
Old 11-12-2018, 05:17 PM
LOL, Is the engine spinning or is the engine having a coming out party???
With a new intake install....
Shut it off
Shut it off
