Old 10-11-2019, 09:43 PM
GNvsTA GNvsTA is offline
Default 77 GP trunk lock cover
Is there any kits or anything out there that I can use to repair my truck lock cover? It came apart on me last night. I was able to get the base off the trunk and it appears that the spring or whatever was holding it together has vanished.
78 Firebird Formula-Cameo white
98 Trans Am-Arctic white
77 Grand Prix SJ-Brentwood brown met
Old 10-12-2019, 12:44 AM
daduck's Avatar
daduck daduck is offline
I have never seen any kit for that and with low production numbers and few GP's of that body style still out there....not likely we will ever see any parts reproduced.
But NOS Trunk Lock Covers do pop up on ePay once in a while.
Old 11-27-2019, 04:50 PM
jd0n88 jd0n88 is offline
I have the same problem with my 76 GP and couldn't find a spring anywhere. I bought a used trunk lock cover for an Olds and hope to use the spring to fix mine. Cheap GM used lock covers can be found on ebay.
Old 12-09-2019, 03:40 PM
1976 Grand Prix 455's Avatar
1976 Grand Prix 455 1976 Grand Prix 455 is offline
When you guys get your lock covers fix. You might want to consider a power trunk release. That's what I've done with my '76 so I don't have to mess with the key back there any more.
Old 04-24-2020, 12:38 PM
Does anyone know what size rivet to use to secure the lock cover to the trunk? It should be a closed end countersunk rivet I believe.
Old 04-24-2020, 02:40 PM
My suggestion to you is to take your cover to Fastenal and see if you can match something up. I remember needing them back in '83 for my '77 SJ. Even the Pontiac dealer couldn't get them. I ended up buying a new cover which came with the rivets.
Old 08-06-2020, 05:30 PM
I finally got around to fixing my trunk lock cover. I used the spring from a cheap beat up cover I bought on ebay and put it on my clean cover. I used rivets from NAPA part # BK6652375.
ID:	546555   Click image for larger version
Name:	GP Lock.1.jpg
ID:	546556   Click image for larger version
Name:	GP Rivet.jpg
