Old 12-17-2019, 11:41 AM
necdb3's Avatar
necdb3 necdb3 is offline
Originally Posted by 77 Canamman View Post
Firestone Wide Oval spare in a 1972 T/A:
Perfect!!!! That's what I remember! The only issue is, I think I remember them on Goodyear tires also. Perhaps GM had the tire manufacturers print that on the tires? I was hoping to see UDDL for one manufacturer and something else for another. It kinda blows a hole in my theory.
The Following User Says Thank You to necdb3 For This Useful Post:
  #82
Old 12-17-2019, 12:12 PM
77 Canamman's Avatar
I know for at least 1977, a tire code on the broadcast sheet would be all encompassing for all GM suppliers, such as Goodyear, BFG, General, Firestone. As long as it was a "GM Spec radial tire". The size and if it was a raised white letter or not would mean a different code.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #83
Old 12-17-2019, 12:14 PM
Lightbulb
Dan moved the Formula from the front garage into the shop under its own power since it first arrived (couldn't get it started to move it out of the hauler and pushed it 200' into the garage!). We are glad it wouldn't start as it needed so much work to the engine and cooling system it could have made needing a more invasive teardown right off the bat. Dan is going through the brakes and electrical right now and he is discovering all the brake components are factory originals...albeit worn, but original. The rubber brake hoses actually look really good, but the rotors and drums need to be turned as the original linings were worn down to the rivits and backers. The front bearings will be checked and repacked as the dust caps look like they have never been removed!
Correction on the secondary side of the carb...it has an 'N' hanger with DA metering rods (0.440" M tips).
Dennis
The hoses might appear fine, but they are notorious for degrading internally, causing calipers not to release or pulling.
  #84
Old 12-17-2019, 01:00 PM
SD455DJ SD455DJ is offline
77 Canamman, I forgot to mention that the hoses are being replaced exactly for your reasons...age and degradation.
Dennis
  #85
Old 12-17-2019, 01:44 PM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Great score fellas!!!
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
  #86
Old 12-17-2019, 02:02 PM
FASTASSBIRD FASTASSBIRD is offline
FAB, Yes, both brackets are still there. Here is a pic of the passenger side smaller bracket and the engine shot shows both, especially the longer driver side bracket. It sure is a pita to remove the air cleaner and is understandable they were discarded early in a RA car's life...but so cool this car still has them!
Dennis
Awesome Dennis. Thank you. Clears up a ongoing debate for sure lol.
  #87
Old 12-18-2019, 08:21 AM
Thanks John! Dennis
  #88
Old 12-18-2019, 08:25 AM
FAB, Here are some close up pics of the brackets.
Dennis
Name:	RAIII Pass Brkt 1.jpg
ID:	526996   Click image for larger version
Name:	RAIII Pass Brkt 2.jpg
ID:	526997   Click image for larger version
Name:	RAIII Drvr Brkt 1.jpg
ID:	526998   Click image for larger version
Name:	RAIII Drvr Brkt 2.jpg
ID:	526999   Click image for larger version
  #89
Old 12-18-2019, 08:34 AM
In the last 10 days since the Formula arrived, Dan has gone through the brakes front to back, rebuilt the original carb, installed new fuel pump and lines, installed new timing chain set, changed to oil & filter, checked the M40 (fluid clean and not burnt), checked the suspension...all original and still tight (!) and got it to run and drive (garage to garage). Next on the to-do list is to go through the electrical and wiring looms.
Had fun bleeding the brakes and then throwing on some F70 whitewalls on 14x7 steel wheels & dog dishes just for yucks. Kinda has that 70's vibe where whitewalls were still popular and common to see on musclecars.
Dennis
Name:	WW on Blk 14x7 Dr.jpg
ID:	527002   Click image for larger version
Name:	WW on Blk 14x7 Ps.jpg
  #90
Old 12-18-2019, 08:39 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Very nice and you guys don't play around
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
  #91
Old 12-18-2019, 08:57 AM
Yeah, we were like a couple of kids at Christmas time...had to tear into the presents right away and couldn't sleep on Christmas eve.
Dennis
  #92
Old 12-18-2019, 08:59 AM
A special shout-out goes to Paul Kilker for alerting us to the car being available early that Saturday morning after Thanksgiving.
THANK YOU PAUL!!!
If he didn't let us know, we certainly wouldn't have it now.
Dennis & Dan
  #93
Old 12-18-2019, 03:24 PM
unruhjonny's Avatar
Dennis;
I have had real trouble figuring out the actual shape of the fuel lines on these cars;
It appears as though there are several reproductions which work with the deep cannister fuel pump, but no clear understanding of how the fuel lines ran veruss the repop lines.
Do you have pictures of the routing of the original line?
Did the repop you buy match the routing or deviate?
Who's line, and which one did you buy?
Thanks for humouring me
1970 Formula 400
  #94
Old 12-18-2019, 04:59 PM
Dennis
Thanks Dennis, now I’m gonna need a moment.....
  #95
Old 12-18-2019, 05:18 PM
Originally Posted by unruhjonny View Post
Dennis;
Jonny, We thought about using a 1971 fuel pump to carb line since the new fuel pump is the deep cannister 71-up style (only deep style we could get new). But we didn't like the incorrect straight fuel line from the T-stat to the fuel inlet, so we elected to use the repro 70 F-body 4-bbl line and had to bend the bottom connection to the fuel pump 45 degrees to fit into the more forward facing pump outlet. We had to use a tube bender to not kink the line and went slowly and test fitted quite a few times to get it to fit correctly. I'll try to get some pictures and post them soon.
Dennis
  #96
Old 12-18-2019, 05:19 PM
FAB, you are too funny!
Dennis
  #97
Old 12-18-2019, 06:23 PM
Jonny, I misspoke regarding the fuel pump. We actually had (luckily) and used an original intact '70 4-bbl w/ deep cannister fuel line (not a reproduction) and slightly bent the lower connection fitting to the '71-upo fuel pump. I almost had it right
Dennis
Name:	Orig Fuel Pump 1.jpg
ID:	527023   Click image for larger version
Name:	Orig Fuel Pump 2.jpg
ID:	527024   Click image for larger version
Name:	New Fuel Pump 1.jpg
  #98
Old 12-18-2019, 06:34 PM
Original C120 and C130 date code rotors with paint daubs intact.
Dennis
Name:	C120 Date Rotor.jpg
ID:	527028   Click image for larger version
Name:	C130 Date Rotor.jpg
  #99
Old 12-18-2019, 06:38 PM
Red Goat's Avatar
Red Goat Red Goat is offline
Wow Dennis! That looks like a great car!! Congrats to you and Dan
Tim
  #100
Old 12-18-2019, 06:41 PM
Tim
Thanks Tim! Stay warm and Happy Holidays!
Dennis
