Old 01-04-2020, 09:13 PM
MyBlueToys MyBlueToys is offline
Default 1970 G/P ASSEMBLY HELP WANTED
I'm looking for under hood pictures for a 70 G/P with air ,Without the air cleaner on .Thanks in advance.Joe
Old 01-15-2020, 05:59 PM
1970GPJ400 1970GPJ400 is offline
Here are some pics I took with the doghouse off - I can get more if you need them. Let me know what angle you're looking for.
ID:	528879   Click image for larger version
ID:	528880   Click image for larger version
ID:	528881   Click image for larger version
Old 01-17-2020, 09:57 PM
Default Under hood?
Thank You,Does anyone know where the small vacuum hose goes that comes from the softball canister that's on the RF inner fenderwell,I can't see it in the book.
Old 01-22-2020, 05:55 PM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
I think It should go to your choke pull-off. The 70's have a dual port choke pull off...
Old 04-12-2020, 07:48 PM
Sprocket's Avatar
Sprocket Sprocket is offline
Yes that.
'70 GP Model J
462 Butler ported 87cc Edelbrock D-ports
RPM intake with Holley Sniper 2
CompCams 236/242 hydraulic roller
Tribal Tubes tri-y headers
TH400 13" Continental "Jim Hand Special"
3.50 9" CurrieTrac, 245/45-18 Front, 275/40-18 Rear
