Old 05-02-2020, 09:47 PM
69Y97GP 69Y97GP is offline
Default 4 Speed GP Shifter Porch location
I know this is a long shot.....I'm about to weld the Shifter Porch to the floorpan of my '69. Although it's sort of obvious where it sits on the tunnel, there is a little wiggle room fore-aft. Does anyone thats done a resto or may have the carpet out of theirs have any pics or better yet, measurements of where it sits relative to the tunnel? I've attached pics to show what I'm looking for. Thanks and stay safe!
ID:	538954   Click image for larger version
Old 05-02-2020, 10:17 PM
Scott Thelander's Avatar
weld ??
why?
Old 05-02-2020, 10:38 PM
tom s tom s is offline
2X Scott.Tom
Old 05-03-2020, 07:27 PM
I sorta figured these were spot welded on at the factory....but now that I look at the part, I see that it wasn't. Just 6 holes in it. So did they just screw these on? Either way, I suppose the factory wasn't all too accurate with the location of these.
Old 05-03-2020, 08:55 PM
Stuart's Avatar
Stuart Stuart is offline
It would have been held down with sheet metal screws. Just put on the hump where it fits best, and use some sealant under it. 3M strip caulk is a good choice - it's cheap, doesn't harden and seals well. It should be available at most any auto parts store.
Old 05-05-2020, 01:00 AM
hawkins69 hawkins69 is offline
I have my 4speed 69 torn down in the shop. In the morning I’ll send photos of where hole is at with measurements. I wouldn’t weld it in position. Screws will work just fine
Old 05-05-2020, 09:49 PM
Photos
ID:	539262   Click image for larger version
ID:	539263   Click image for larger version
ID:	539264   Click image for larger version
Old 05-06-2020, 02:47 PM
I always found that the porch (if not bent up just sort of falls into place). The location on the GP would be identical to all 68-72 A bodies so should be plenty of pics online.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
