Old 05-04-2020, 06:40 PM
EuroFormula EuroFormula is offline
Default Ram Air Cleaner - Modification
I asked this once here years ago, can't find the thread anymore. Maybe someone has seen something over time.
My question: I have had this Ram Air air cleaner for years. Just dug it out of my parts stash. Always wondered why someone would go to the trouble of welding in the tubes/plates? Any real benefit to this? Someone back in the day said 'hillbilly breather' but can't figure out why they would do it. They did paint it orange, so maybe no logic involved
Near as I can tell, it is a originally 73-74 Formula piece.
ID:	539160   Click image for larger version
ID:	539161   Click image for larger version
Old 05-04-2020, 07:01 PM
Beyond odd, have never seen a mod like that. Have had owned ove a dozen RA breathers of that style. Should be easy to return to stock appearance, be happy no one has hacked the base to clear the fuel bowls on a center hung Holley.
Old 05-04-2020, 07:19 PM
Joe's Garage Joe's Garage is offline
Default It might be some kind of hillbilly nitrous injection (or some other power-adder)
I remember seeing a setup similar to that probably thirty years ago where the driver controlled the injection of straight oxygen using a propane cutting torch control from the driver's seat.
Interesting stuff anyways.
Old 05-05-2020, 12:05 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
It actually looks well executed to me, but other than someone's modified breather setup I don't have much to suggest. But it could have been one of those crazy ideas like where they would put an anode and cathode into a solution and run current through it to generate hydrogen and oxygen and pipe it into the air intake to make "more power" or better economy. Lots of crazy things were tried during the fuel crisis.
Then again, the baffle plates tend to have me think these were just crankcase breathers, even though GM had an adequate one already there with its own oil separator filter deal.
I built it one piece at a time and it cost me more than a dime.
Old 05-05-2020, 07:11 PM
unruhjonny's Avatar
That's a good idea!
I was going to suggest that it was possibly some sort of water "injection" setup, as many mid to late 1970's articles I came across seemed to suggest that the fuel was so bad, that water injection was a good remedy to high compression engines and the swill you got at the pumps.
1970 Formula 400
Old 05-05-2020, 08:32 PM
Held for Ransom's Avatar
No clue on why.
Can you post a picture of the underside? I should be able to ID year.
So long, farewell.
Old 05-07-2020, 03:42 PM
Interesting stuff indeed, thanks guys!
Here is a pic of the backside
Old 05-07-2020, 03:48 PM
While we are at it, I have this one, too. Looks pretty original. Using this one on my car at the moment (with a different lid ;-).
Any way to tell if for a Firebird or a GTO or were they identical? This one has the posts or whatever they are called for braces.
ID:	539505   Click image for larger version
ID:	539506   Click image for larger version
Old 05-07-2020, 04:30 PM
unruhjonny's Avatar
the Firebird Formula and GTO's used the same aircleaners;
I know someone who would love to get that second airlceaner off of you - and trade you for another one.
I actually tweaked my 455HO SR aircleaner to add those studs.
1970 Formula 400
Old 05-07-2020, 06:20 PM
PontiacJim1959 PontiacJim1959 is offline
How about drain tubes when water got sucked in? The baffles kept big leaves/debris from plugging the tubes.
Old 05-07-2020, 07:07 PM
Orange unit is a '73. If you think it's original to your car, is your car a 400 or 455?
If I had to guess on the other unit, I would say it came from a '71 GTO.
So long, farewell.
Old 05-07-2020, 11:57 PM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
EuroFormula I’m that guy that unruhjonny was talking about. My 71 formula has the non HO ram air air cleaner.
Old 05-08-2020, 04:55 PM
See PM
The Following User Says Thank You to EuroFormula For This Useful Post:
Old 05-08-2020, 04:58 PM
Cool, thanks! Not original to my car, mine didn't come with it from the factory. PO had installed the Ram Air, but had removed the air cleaner prior to the sale. Got both of mine over time afterwards.
Old 05-08-2020, 09:07 PM
muscle_collector's Avatar
they actually made different ones. the firebird uses one that lets it sit lower for hood clearance. unless you know what you are looking at its hard to tell the difference unless they are side by side.
Old 05-09-2020, 10:20 AM
I don't think so Gary. For '71 and '72, they had the same pick code/part number for both models.
So long, farewell.
Old 05-09-2020, 02:43 PM
don't know what to say, ive got both styles. my all original A bodies had the one type and my birds always had the other type.
Old 05-10-2020, 07:37 PM
If they have the decals on the side, I'd love to know the PN of each unit.
So long, farewell.
Old 05-19-2020, 07:29 PM
Black one is RQ 6486684. Orange one has no trace of a sticker.
Old 05-19-2020, 07:49 PM
Michaels76SE Michaels76SE is offline
I bet they ran a hose from each tube to each valve cover for a PCV effect
