Old 05-05-2020, 04:00 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Default 1970 Ex Tips placement
I thought there were pictures on the site at one time showing where the chrome 1970 exhaust tip placement should be and proper angle etc.? Can someone post up a picture or the thread for me please? I cant seem to find it. Thanks.
1970 T/A
Old 05-05-2020, 07:06 PM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
as I recall there is nothing conclusive.
They were intended to somewhat follow the bottom of the quarter panels, and peek out past the tail panel.
From a rear-on look, they can ever so slightly be point towards each other.
But!!
It seems as though most people "correct" it, to make them not point towards each other.
Here's a good picture I ran across again this morning:
they are ever so sublty pointed towards each other.
Here's a nice post with a member's input:
https://forums.maxperformanceinc.com...22&postcount=7
this is also worth pointing out:
Originally Posted by RamAir View Post
The factory marked the lower valance to place the extensions which would have an inward direction.
Originally Posted by Transamric View Post
FWIW I agree with Lloyd that the tips were originally angled slightly in towards the center. As the owner of two original exhaust TA's, they were both assembled that way. This slight angle placed them directly under the curved, stamped impressions in the lower valance.
However I do believe that, with the bumper design change in '74, this practice changed to straight parallel.
Originally Posted by skunkwerks View Post
... My point exactly is parallel side view to body line (not pointing up in the back and slightly canted inward. Norwood's look perfectly tucked and where they should be. They look correct to me.
Your opinion is yours. Assembly line variation did exist.
... I have seen to many originals tucked up and not extended like most I see. canted inward and not canted inward depending on adjustment of tail pipe frame holding bracket.
Humans installed this stuff not robots. ...
Although it's not an exact science, I hope this helps.
1970 Formula 400
Old 05-05-2020, 08:32 PM
Norwood's Avatar
Norwood Norwood is offline
I think you will get a lot of opinions. I agree that they have a slightly inward position that matches up with the indents in the tail panal
Old 05-05-2020, 09:38 PM
dpoltzer's Avatar
Thanks Gentlemen, this is exactly what I was looking for. Dave
1970 T/A
Old 05-05-2020, 10:03 PM
Here's one at more of a level side view.
Old 05-05-2020, 10:22 PM
dpoltzer's Avatar
Thank you Keith.
1970 T/A
Old 05-05-2020, 10:38 PM
muscle_collector's Avatar
want to do them like they came out of the factory? point one in one direction and point the other one at a different angle. factory tips were horribly inconsistent in the way they were mounted and got worse thru the 2nd Gen run
Old 05-05-2020, 11:50 PM
Aus78Formula Aus78Formula is offline
The reason they pointed inwards was probably just trying to line tips up with cutaways with a system that didn't want to exit there.
