Old 05-12-2020, 09:39 PM
BOB VIDAN BOB VIDAN is offline
Default Man I Feel Stooopid
Did Pontiac ever have a 5 x 4 1/2 rally II wheel? If so, when? If not, I have 1 of none. See picture, 15"
Practicing social distancing for 65+ years
Old 05-12-2020, 10:00 PM
Not that I am aware of, Possibly Canadian? Just a thought.
Old 05-12-2020, 11:33 PM
How did you measure it?
Old 05-12-2020, 11:59 PM
77 TRASHCAN's Avatar
Never seen that method, cool. I usually have a sharpie in my pocket. I draw an arc between 2 holes and measure across from the center of the hole opposite...not real accurate...
Shut it off
Shut it off
Old 05-13-2020, 05:13 AM
Measured as Scarebird shows. I'll grab a picture tomorrow.
Old 05-13-2020, 06:38 AM
Probably late 80's-90's
Came on Bonnie's, GP's, Aztec, Montana's
What's the date code and wheel code on it?
Old 05-13-2020, 11:32 AM
Full size is 5" bolt pattern I think?
(on the older cars, pre-80's)
Old 05-13-2020, 09:23 PM
OK, I"m stooooooooooooooooooooopiiiiiiiidddddddddddddd. I measured CTC on the studs as seen in the pics. If I ever make a fool of myself in public, don't tell anyone, KKKKKKKKKKKKK??
ID:	540088   Click image for larger version
ID:	540089   Click image for larger version
ID:	540090   Click image for larger version
Old 05-13-2020, 10:04 PM
KG coded 15x6 rally II...
often color keyed to body color, & installed on late '70's Esprits, or on Catalinas or Bonnevilles with a 7.5 10 bolt.
Old 05-13-2020, 11:28 PM
Seems like I remember a Sunbird having those wheels, a 77...
Shut it off
Shut it off
Old 05-14-2020, 07:45 AM
No 1st generation 76-80 sunbird had those wheels from factory, it could have if a 5-lug conversion was done, they did use the 4-lug Vega/Monza rally wheel with Pontiac Center caps though.
Old 05-15-2020, 12:34 PM
Were the Sunbird wheels a 4 spoke version of the Rally II? Or am I just thinking of the 4 spoke Vega Wheels???
Shut it off
Shut it off
Old 05-15-2020, 03:59 PM
They used the 4-Spoke Vega Wheels, just with Pontiac Center Caps.
This is the best picture I have of my 77 Astre, the day I drug it home. The center caps are missing but you see the 4-lug 4 spoke Rally Wheels that were available on Sunbirds & Astre's.
