Old 05-18-2020, 11:57 PM
headhunter86 headhunter86 is offline
Default 1966 “YC” 389
Block casting # 9778789, date code:A26 with “YC” code
“N” crankshaft casting # 9782646
Heads casting #092, Driver side date code:B56, Passenger side date code:B126
2 barrel intake casting # 9784438, date code: B76
Engine disassembled, #5 rod spun. Crank needs to be ground. Block is std bore with very little ring ridge in cylinders. Heads are assembled.
Also includes front cover, water pump that needs rebuilding with cast impeller, connecting rods with pistons, harmonic balancer with crank pulley, flexplate, camshaft retaining plate, fuel pump eccentric, windage tray, oil pan, valve covers, and misc. bolts. Located in NW Iowa. $325 OBO. Call me at 712-240-2019 if you would like to discuss this further. Thanks, Ken
Old 05-21-2020, 08:56 AM
a421cat a421cat is offline
If you decide to part your engine out I would be interested in the oil pan and oil filter adapter.
Thanks, Bill.
Old 05-21-2020, 10:18 PM
I will keep that in mind Bill thanks.
I am open to any fair offers.
Would this block be a good choice for a stroker motor?
Old 05-21-2020, 10:39 PM
Bill I am pretty sure I have an oil filter adapter and I may have an oil pan also. Give me a call or message me. Thanks, Ken
