Old 05-31-2020, 08:28 PM
duke455's Avatar
duke455 duke455 is offline
Default Leaf spring question
I know this has been discussed probably over this forum with different cars but I'm looking for the right Spring for my 73 formula..at least stock ride height or an inch or two lower.. if you have some pictures of your rides and the Springs that you used could you post them up so we can talk about it..thanks
Old 06-01-2020, 08:36 AM
Formulabruce's Avatar
if you don't want stock, Norwood (Craig) has a nice set on his '70 Trans Am. other than that, Eaton sells what they show as the exact stock springs. Having bought a couple sets of the '73 springs, I would buy a set for an Esprit. they seem to, like 99% of places "over arch" the new springs and they tend to sit too high. I like a 119 lb rated spring with very agile away bar that moves and works. Stock rear height was 1/2 to 7/8" lower in rear. All rear springs PRE 1973 are different numbers right and left which I would stay away from.
Old 06-01-2020, 08:38 AM
duke455's Avatar
Default springs
ok..thanks Bruce do you have a part number for the ones that you have used from eaton ?
Old 06-26-2020, 12:16 AM
whitebird400's Avatar
whitebird400 whitebird400 is offline
I believe Classic Industries Firebird catalog has the Eaton part# and specs for all Firebird models with or without a/c and engine type.
Old 06-26-2020, 10:10 AM
78w72 78w72 is offline
another option is PTFB springs. the "GT" springs sit about 1.5" lower than stock & are high quality springs that ride & perform great for handling, probably a little too stiff for serious drag use. heres a pic with 225/70 tires & their ~2" drop front springs. very happy with the ride quality & performance & the ride height is just about perfect.
Old 06-26-2020, 02:02 PM
Norwood's Avatar
Norwood Norwood is offline
PTFB GTsprings in back. Saggy stock in front.
