Plug size?
I need to pull out the plug next to my distributor to hook up my oil pressure gauge. It's a square drive. But 1/4 is too small and 3/8 is too big. Which size is the plug? The plug was out when the engine was rebuilt so I know it will come out.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
The socket is a 5/16" square.
Thank you! Wasn't sure if it was 5/16 or 11/32.
Snap On tool P/N PPM410. Or you can grind a 5/16" square on a head/main bolt.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
if your 5/16 tool is too loose ,mac makes a 8mm square 3/8 drive tool.sc174p2 , this is a chrome plated one.
CAROLYN JONES(1930-1983 Actress)may she never be forgotten!! |
Thanks guys! I haven't had a chance to try a 5/16 square yet since the car is currently off at paint. I'll probably have to pull the distributor though to get the plug out.
On my 73 factory engine, the plug was extremely tight. Sounded like a gun went off when it broke loose. Thought i broke my tool but the plug did move. Then i checked my knuckles for missing skin.
If i find this again, i'll try a little heat around the plug.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
good day, I have the plug out, what size bushing fits in there to adapt to a autometer oil pressure sender?
THANKS
https://www.facebook.com/KauffmanRac...6873234225938/ KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9". 552HP 594 TQ |
Your sender is 1/8” pipe male, I forget if the block passage is 1/4” pipe or 3/8” pipe.
