Rally II wheels Backspacing measument
Can anyone confirm or not if the Pontiac Rally II wheels that's on the sec gen cars are 4 or 4 1/2 inch backspace looking for verification...thanks
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 11-27-2019 at 07:34 PM. |
The set I have were off a 73Formula. They looked to me like 4.25 when I was measuring.
So your saying 4 1/4 Inch...hmmm
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
The last ones I measured were 4-3/8” or a tad more.
Definitely not 4”.
yeah definetely not four. I was thinking they were 4 and a quarter but they might have been a little more. Its harder to measure with tires mounted on the wheels.
My 15 inch HM code rally’s (can’t remember year) are 4 3/8
If you can have what you want, try to get the most, I doubt it will be over five..
Just measured a 15x7 it's about 3 3/4 inch definitely under 4
You sure you’re not measuring a 6” wheel?
No way any factory 15x7 measures less than 4-3/8”. Most aftermarket ones are 4”.
Heres the rim measured outside lip to outside lip then inside to inside
Aren't the rims stamped ??? 15x??? Looks like a 6inch your right... Didn't know they can on 15x6. Thought that was 14 inch
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 12-02-2019 at 03:09 PM. |
That’s a 6” rim. Bead to bead is how they’re measured.
Wheel diameter is also measured at the tire mounting bead, not the rim edges.
Yeah I did not know they came 15x6 learned something new thanks bman the search continues
