Old 12-30-2008, 04:00 AM
Novaracer Novaracer is offline
Thanks guys,I will update pics as work gets done.happy new year!
Old 02-05-2009, 02:10 PM
Well i got all the welding and griding done and started to bodywork the areas I welded in.I ordered the one piece floor the other day so I am prepping the car to install it.I removed the convert only braces which need a little repair before they go back in.I also cut out the rear part of the floor and set the car up on stands while still on the rotisserie along with some bracing to get ready to cut the rest of the floor out.
Old 02-05-2009, 02:12 PM
Got the new floor today,it's a goodmark piece.
Old 02-05-2009, 08:43 PM
3 Chiefs's Avatar
3 Chiefs 3 Chiefs is offline
Cool!!! Please take and post many pictures. You are really doing a good job. Do you think the new floor has all the detail it should? From your pictures, it looks to be a quality piece.
Thanks for posting your pictures.
Paul
I never met an old car that I didn't like.
Old 02-06-2009, 12:11 AM
So far the pan looks really good.I need to reuse the brackets for the rear seat and the front buckets otherwise the seatbelt mounts are there which I thought i would have to reuse the old ones in the rear.so far I am really happy with it.
Old 02-06-2009, 12:15 PM
tripower's Avatar
tripower tripower is offline
Novaracer, nice work. If I could only learn to metal work and weld like that, I'd be moving along on my project too. Keep the pics coming!
Norm J
Old 02-07-2009, 01:55 PM
jsn829 jsn829 is offline
Novaracer, you are doing a great job. I know you said the wheels were 18s, what size tires did you run?
Old 02-07-2009, 09:04 PM
they are 295/45 and 255/45 18 nittos
Old 02-08-2009, 10:22 AM
Txbobcat Txbobcat is offline
You do great work The car is looking good
Old 02-09-2009, 02:42 AM
got the floor in and positioned with sheetmetal screws then welded the braces in and a few other parts.Then I got it off the jackstands so I could turn the rotiserie again to weld up the bottom better.still a bunch of welding to finish but getting there.
Old 02-09-2009, 12:27 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Looks a little smoky in the room - is that from welding, smoking or just the camera? Great looking work by the way - takes a lot of dedication and talent to go this far into a project; I admire that effort!
BJ
Old 02-09-2009, 01:11 PM
Thanks and ya it's from welding.
Old 02-16-2009, 01:09 AM
The floor is now 98% welded in.I have one section to weld and it's done.I also have to weld in the bucket seat brackets etc that I cut off the old floorpan.Here are a couple pics of the braces repaired and welded back in.
Old 03-23-2009, 05:37 PM
Old 03-23-2009, 05:38 PM
Old 03-23-2009, 05:39 PM
Old 03-23-2009, 05:41 PM
Got the floor painted up today.I have the poly bushings and the body should be going back on the frame in the next couple days.I also got the fuel line and pump in.
  #38
Old 03-23-2009, 06:31 PM
slowgto slowgto is offline
Stick with the white interior. Black gets very hot in the sun.
Great restoration.
  #39
Old 03-23-2009, 10:42 PM
3 Chiefs's Avatar
How about some of your thoughts on the floor pan. Do you recommend going this route? Would you do it again?
Paul
  #40
Old 03-23-2009, 11:44 PM
the floorpan is awesome,it fit really well and looks right.I would definetly go this route again.
