Old 02-25-2017, 06:30 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Default Pump gas boost
The new Subaru STI's run 18 psi, I know a guy with a Ford Focus RS running 30 psi on pump gas, that ecoboost puts 450 to the ground.
How do they get away with that boost on pump gas, is it just a better head design? Cam design?
What is the highest boost you guys run on pump gas with no meth. Just pump gas
Old 02-25-2017, 08:29 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
My son's 2007 Madzaspeed 3 is direct injected and he turns the boost up to about 19 psi on premium pump gas.
Old 02-25-2017, 09:31 PM
What compression ratio do they run?
And yours?
Old 02-25-2017, 10:03 PM
Tom Vaught's Avatar
Boost Engineer
You can buy E-85 gas at a bunch of gas stations locally. 85% ethanol and 15% gas.
So if you put in a bit less E-85 fuel in the tank and add a bit more gasoline you get a E-70 blend. This Coyote has made over 1400 HP RWHP with moderate turbos fro Hellion Turbo. 29 PSI of boost but good heads from Ford as well as other Ford components.
https://www.svtperformance.com/2016/...-2015-mustang/
So if you want to make great power on Pump Gas (ethanol and gas mix) then this is a good example of a street 8 second vehicle. ECOBOOST! ECOBOOST!
Tom V.
Old 02-26-2017, 08:14 AM
taff2's Avatar
taff2 taff2 is offline
No doubt the vehicles electronics systems have a bearing on how these cars can run high boost. Myself, I prefer adding Toluene to pump gas to be able to run higher boost,cheap and easy.
ps, back in the early '90's I had a Ford Sapphire Cosworth saloon, with a Superchip in the factory ECU it ran up to 21psi of boost on ordinary pump fuel (no Toluene-I hadn't discovered it then!), though I did fit a home made water injection system later on for safety's sake.
Old 02-26-2017, 11:40 AM
JSPONT's Avatar
How much do you add per gallon?
Old 02-26-2017, 11:57 AM
Tom Vaught's Avatar
Boost Engineer
Banks was running Toluene back in the 70s at a 4 to 1 ratio. 4 parts pump gas to 1 part Tolulene or to say it another way 20% of the tank of gas was Tolulene.
Tolulene is extremely dangerous as far as causing cancer later in life if you breathe the fumes very much. A very good respirator designed to trap Tolulene vapors before they reach your lungs needs to be in place.
Tolune is a big bang for the buck fuel octane improver but a very dangerous one as far as a cancer creater.
Tom V.
Old 02-26-2017, 01:13 PM
JSPONT's Avatar
Tom V.
Forget it, I rather use a meth kit with washer fluid!!
Old 02-26-2017, 02:19 PM
70 bird's Avatar
70 bird 70 bird is offline
X2 Walmart had a sale a few weeks back, -20 washer fluid $1.59 a gallon. I picked up 10 gallons.
Old 02-26-2017, 07:09 PM
Tom Vaught's Avatar
Boost Engineer
You will not see me running the stuff in my boosted engines either.
The Snow meth kits seem to do a good job based on feedback from Mr. 70 bird, (;>)
Tom V.
Old 02-27-2017, 08:49 AM
taff2's Avatar
What a lot of people don't realise is that ALL pump gas has Toluene in it from the pumps! Up to 17% in some cases, it's what the fuel companies use to make the higher octane pump fuels. If it's mixed outside and you wear gloves there is no problem, at least no more than if you mix race gas with your pump gas,or if you wash parts in gasoline. Race gas has a higher percentage of Toluene, that's what makes it high octane!
20% Toluene ( 1 gall Toluene to 4 galls gas) will give you a C16 type fuel- excellent for high boost combos,you can use more boost/more timing.
10% Toluene will give you a C12 type fuel good for low boost or high compression n/a combos.
5% is good for older high compression street engines, 10.5- 11.5 compression etc.
We tried 2.5% in my son's high compression 4 stroke dirt bikes, throttle response was much quicker and the bikes ran better all through the range, these bikes have 13.5 to 1 compression ratios from the factory and rev to 12-13,000 rpm.
I've used Toluene succesfully for about 15 years without any problems, apart from my hair falling out that is-though some might say that's down to age!
Old 02-27-2017, 12:07 PM
Tom Vaught's Avatar
Boost Engineer
Obviously you have "done it", as did Mr Banks years ago.
I don't wash my hands in gasoline since the late 60s, I don't put my hands in Trans fluid, and I don't get around chemicals like benzene and Methanol Vehicles while they are idling their engines. A Fact: Chem Lab at the carb company I worked for. 10 guys in the Chem Lab, all 10 guys dead from Cancer related issues. Same company sent Tech out to build carbs at the track for people (for free) while they were racing. Hundreds of carbs in a week-end modded. Every guy on that crew dead from Cancer. Makes you think.
EFI has helped that deal a lot with people not getting near the chemicals and on their bodies. Still does not cover the Methanol vehicle exhaust issues.
I walk away when I hear "I love the smell of Methanol in the mornings".
Tom V.
Old 02-27-2017, 03:59 PM
Fast 69's Avatar
Fast 69 Fast 69 is offline
What ratio would you mix Tolulene to 110 race fuel to get 116?
Old 02-27-2017, 09:48 PM
70 bird's Avatar
Another good one to stay the hell away from is M.E.K. methyl ethyl keytone. I see guys at work everyday cleaning aircraft parts with that crap. just spill a few drops and it will stink-up the whole hanger.
Old 02-28-2017, 06:53 AM
taff2's Avatar
I've never mixed Toluene with race fuel- I always start with the low octane chickens piss they sell at the pumps- but 10% would be a good start.
I'm pretty careful when mixing up fuel batches, I do it outside in the fresh air and wear rubber gloves. I agree that it is nasty stuff, but any chemical that actually 'works' usually is!
ps,don't store Toluene in plastic containers in the workshop that you work in, it evaporates through plastic containers and the place will smell of it.
Old 02-28-2017, 12:27 PM
Chemicals that can strip paint or melt plastic deserve all the protection attention you can give.
My cancer(multiple myeloma) is in same family of blood cancers as lukemia. Rare and only commonality seems to be chemical workers, petroleum industry, and mechanics. No specific ties have been determined yet.
I grew up next to a place that made products with asbestos in them, was down wind from refineries, played in fields with white mud, walked through ponds that ooozed smelly oil-like stuff. Plenty of jet fuel down my arms draining sumps on B52's not to mention showers in deicing fluid even hydraulic fluid. MEK yep, but I tried to avoid that stuff as it burned skin pretty easy...toluene...in the 60's building models, glue was full of it(till idiots started sniffing the stuff)I think it was in model paint as well, it was common in gasoline not to mention tetraethyl lead . My go karts saw methanol, ethanol, model plane nitro, ether. I swam in the Niagara river long before the clean air/water act. Its a wonder I dont glow in the dark lol.
Yeah,be careful with any chemical you're handling including household stuff.
Old 10-25-2019, 07:19 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What is the consensus for pump gas ( only, no alcohol injection) boost psi?
Old 10-25-2019, 08:18 PM
Tom Vaught's Avatar
Boost Engineer
Even with no alcohol, question is too broad as there are at least 3 grades of no lead pump fuel out there today.
Tom V.
Sad that Bruce is no longer with us. RIP Bruce
Old 10-25-2019, 08:46 PM
ponjohn's Avatar
Tom V.
Oh geez, I didn't know.
93 octane.
Old 10-26-2019, 12:35 PM
JSPONT's Avatar
This also depend on compression, cam choice, timing.... but 15 psi is safe on 93 octane. I have friends running 18psi with no issues, but I think that is pushing it. It leaves no room for error.
