Old 02-01-2019, 03:24 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Default 74 GTO running lights question
I have a 74 GTO that was a bracket car, that I'm now putting back on the street. The original wiring is in ok shape, but some of it needs to be gone through.
When the the headlight switch is off and the car is running, I assume all the running lights should be off.
When the the headlight switch is pulled halfway, to the running lights position, which lights should be on besides the taillights? Rear quarter and front fender marker lights? How about the lights in the grill?
When the headlight switch is pulled on, Do all the same running lights stay on? Along with the headlights coming on, of course.
Anyone know of a 74 GTO wiring diagram available online?
Thanks.
www.lancablingsolutions.com
Old 02-07-2019, 10:58 AM
74gto's Avatar
74gto 74gto is offline
When you pull headlight out one click, you should have all running lights. Rear tail lamps, side marker lights, and lights in the grill. Pull all the way out all light including headlights should be on.
74 GTO 406 T400
74 Firebird 350 4-speed
68 GTO Convertible 400 T400
76 GP LJ 400 4BBL T400
78 Chevy 1/2 Ton Truck
Oh yea I love my wife very much
For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm
Old 02-11-2019, 01:13 PM
Mean Green's Avatar
Thank you.
Old 02-12-2019, 01:34 AM
Red74Goat's Avatar
Red74Goat Red74Goat is offline
I don't know of an online wiring diagram, but I have a copy of the 1974 GM Pontiac Service Manual and it has the foldout wiring diagrams in the back. Probably worthwhile investment if you have a significant redo on the car wiring. You can usually find a used copy on ebay for about $30.
Also, you can buy a nice color coded 11" x 17" laminated wiring diagram from Ames Performance. Part # M100AL - $16.00. El Monte slim posted this part from Ames a few years ago.
Good luck.
Old 02-12-2019, 03:23 PM
Rob B's Avatar
Rob B Rob B is offline
And if all else fails, I believe M&H wiring sells the wiring harnesses for the 74 GTO.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
