Old 06-01-2019, 10:52 PM
70badboy 70badboy is offline
Default 74 GTO letter code on block?
On the 74 GTO, what would be the letter code stamped on the front of the block for a manual transmission? Thanks Steve
Old 06-02-2019, 07:34 AM
WP
Old 06-02-2019, 03:56 PM
Does the 6 digit number stamped on the front of the block match the last 6 digits on the VIN? Thanks Steve
Old 06-02-2019, 05:08 PM
unruhjonny's Avatar
no, that's an engine unit number;
the partial vin is stamped vertically down beside the timing housing, opposite if the fuel pump.
1970 Formula 400
Old 06-02-2019, 08:01 PM
Here is my question. The last 6 digits of the VIN (111706), the number stamped on the block is 272916 WP. Are they suppose to match to be the original motor? Thanks Steve
Old 06-02-2019, 08:14 PM
If that number is above the WP, it will not be for the VIN.
It is called the engine unit number or motor unit number or some other things.
The VIN of the car is down lower on the block same side as the WP.
It will be next to the timing cover, if still in the car may be hard to see because of crud and the radiator hose hiding it.
(as was said earlier)
It will look something like 24L111706 or 24W111706
(if it's the original)
I collect that info on the engine unit number.
What is the block date code?
(back of block by the distributor)
Old 06-02-2019, 08:27 PM
I will find out and let you know. Thanks for clarifying the numbers for me. Steve
Old 06-03-2019, 09:26 AM
Hey johnta1, here is the information on the block. Date code K013, serial number 23L111706. Hope this helps. Steve
Old 06-03-2019, 09:44 AM
Thanks!
That serial number is from the engine?
If so, it is the original engine.
Old 06-03-2019, 10:23 AM
yes, it was from the motor. Just got back info from PHS. It is a 74 GTO, 3speed on floor. Color Pinemist Green. Steve
Old 06-03-2019, 04:29 PM
Cool!
