Old 11-08-2019, 04:40 PM
ErikW's Avatar
ErikW ErikW is online now
Default Stroke choice for turbo motor
So, I am building a twin turbo motor for 2020 Drag Week. I have a 1970 400 block bored 30 over with Program center caps, arp studs. I have, on order from Dave at SD Performance, a set of 95cc 325cfm Edelbrock round ports with a few turbo tricks including T washers.
My issue is rotating assembly choice. I have a very nice Crower billet 4.25 stroke crank and 6.800 Oliver rods on hand but from what I've been reading, everyone is suggesting a shorter stroke.
So what would be the disadvantage to me using the 4.25 combo, and the advantages to selling it and going with say a 4.0 stroke? Thanks for any input.
Erik
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
Old 11-08-2019, 06:14 PM
Tom Vaught's Avatar
Boost Engineer
I would run it with the parts you have....
Good parts are worth more from the durability side vs using a Scat Forged crank that is 4.00 inch stroke. Drag Week you want durability, especially with a Factory Block (even with splayed caps). You would want to spend your time getting every thing ready for the event vs worrying about the perfect combination the first year you run the event.
Tom V.
Kelvin Poe has run the event (as has Richard with the 65 GTO (from Canada)).
I would try to talk to BOTH of them before you get very far in your efforts.
Richard has run a boosted 65 GTO for several years now.
Old 11-08-2019, 07:31 PM
JLMounce JLMounce is offline
Isn't there also a member here with a turbo poncho equipped sunbeam tiger? I believe he runs in the 8.80's and does so reliably. Might be worth looking at his setup as well.
For the life of me I can't remember his username. I think 1320 on YouTube did a short video on the car from drag week a couple years back.
Edit. Here's the vid. https://www.youtube.com/watch?v=-GVw1ga0ZWU
-Jason
1969 Pontiac Firebird
Old 11-09-2019, 08:41 AM
taff2's Avatar
taff2 taff2 is offline
The only downside I see to running the long stroke crank is the extra side thrust loading that it will put on a factory block, that may or may not be an issue over time. A shorter stroke crank could have a better R/S ratio/ better piston compression height etc. But you already have a nice quality Crower crank - certainly better than any Scat/Ohio forging.
Old 11-09-2019, 11:20 AM
ErikW's Avatar
Yup, that's my dilemma. I need to order a custom set of pistons and can't decide on stroke. Probably just going to use the Crower/Oliver combo.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 11-09-2019, 05:13 PM
charlie66's Avatar
Depends on what level of power you're looking for...
Street driven car short stroke . Track car, either but i guess the long stroke in the end wins if you can get it all to the ground ..
Disadvantage would be extra torque. More of a challenge with traction .
Going from a 4.00 to 4.25 its not woth it because you have a real good crankshaft already ..
If you went to a 3.75 id say it would be worth it..
That would be my choice..
My Half AN Injun.....
Old 11-09-2019, 05:16 PM
charlie66's Avatar
I met him this summer at Norwalk . Very nice guy. Cool car...
Old 11-09-2019, 05:34 PM
70 bird's Avatar
70 bird 70 bird is offline
Run what you have. Traction may or may not be an issue depending on your rear suspension set-up. If you need traction help your converter and axle ratio become a very important choice. I have a 462 with a tight converter and a 3.08 gear. With drag radials this works well for me on the street.
Old 11-09-2019, 05:45 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is online now
4.25 every single time.
*** THE BIG BRACE is here ***
Old 11-09-2019, 08:35 PM
ErikW's Avatar
Thanks guys. 4.25 for the win. Appreciate the responses. I'll post more as the build progresses.
Erik
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 11-09-2019, 10:25 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
My 4.5" stroke combo has been working well for over 10 years, my new combo will be a 4.25 stroke. I say run your 4.25" stroke.
Old 11-11-2019, 12:47 AM
JSPONT's Avatar
JSPONT JSPONT is offline
4.25 here, just had it apart, 3 years of street stuff, 8-9k miles, bearings looked new.
Old 11-11-2019, 08:28 AM
GTOGEORGE's Avatar
I don't have a turbo BUT I've always liked the GRUNT of a 4.5" stroke engine!
GTO george
Old 11-11-2019, 03:27 PM
ErikW's Avatar
I've got one of them in my N/A 64 GTO. She'a a torque monster.
1964 GTO
9.76 @ 137mph
2009 G8 GT
