Old 11-19-2019, 10:20 PM
Red Box Rebel Red Box Rebel is offline
Default '68 Disc Brake Spindles
Question:
Can the front disc brake spindles used on the 1968 GTO with 4 Piston Calipers, also be used with the '69 and later Single Piston Calipers? I know the caliper mounting brackets are different, but are the spindles the same, and if they are not, can they be used with both the single piston and four piston calipers?
Old 11-19-2019, 11:43 PM
242177P's Avatar
242177P 242177P is offline
Same spindle, they just changed the bracket.
The Following User Says Thank You to 242177P For This Useful Post:
