Old 02-02-2020, 10:48 AM
tom s tom s is offline
It was in a M/T chassis.Tom
Old 02-02-2020, 12:37 PM
Default This pic?
Found this pic in an article. Writer thought the engine might have had a 180° crank.
Clay
Old 02-02-2020, 01:56 PM
Tom Vaught's Avatar
Boost Engineer
Thanks for the Great Naturally Aspirated M/T Pontiac picture.
It would be very easy to do a DUAL Blow-Thru Carb Bonnet set-up (with the AFBs) like the Paxton Supercharged engines had). A guy in Kansas has a "Pontiac Paxton Supercharger" set-up for a PONTIAC Engine on the shelf.
What a cool Street Rod intake set-up that would be.
Tom V.
Old 02-07-2020, 05:29 PM
Don Keefe's Avatar
Don Keefe Don Keefe is offline
PY VIP
I wouldn't be surprised if it was a 180-degree crankshaft in that engine. It would run like two slant fours. I always wondered if the M/T crossram was developed to be used with a flat crank, it would probably work well in that application. Thompson was very much an engine scientist and I will bet that idea crossed his very fertile mind.
Don Keefe,
Founding Editor-in-Chief, Poncho Perfection Magazine (October 1, 2015- present)
www.ponchoperfection.com
Contributing Editor: Collectible Automobile (1999- present)
Author:
"Grand Prix: Pontiac's Luxury Performance Car" (Released April 27, 2007)
"How to Restore Your Pontiac GTO" (Released July 15, 2012)
"Pontiac Concept and Show Cars, 1939-1980" (Release Date April, 2016)
"Leave the gun, take the cannoli."
Old 02-07-2020, 07:45 PM
Interesting water pump,looks like a Sherwood or Jabsco marine pump.You see there how to plumb the water to each head.Also the chain sprocket on the crank is a wonder?Damn I wish Fritz was still with us.Tom
Old 02-10-2020, 05:35 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Came across this on FB....
*** THE BIG BRACE is here ***
Old 02-11-2020, 02:33 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
All the engines ever used in the streamliner (both N/A and blown) were iron blocks.
As for the "-2", the whole D-number was assigned and stamped by PMD.
Why do you say "1960"? The first mention by journalists of the initial Harvey Aluminum castings was during 1962.
Old 02-11-2020, 08:22 AM
taff2's Avatar
taff2 taff2 is offline
Why on Earth would they cast a performance ali block-but leave the valley area open?
Old 02-11-2020, 10:01 AM
Tom Vaught's Avatar
Boost Engineer
Agree, what were they thinking?
Joey Fair at Mayfair Automotive in the early 60s (not sure if I have the business name right), was adding the turn-buckle mod to the old mechanical FI intake manifolds (as the extra strength from a factory 4 barrel style intake was no longer there) to help in the weak Pontiac stock valley area from spreading and cracking in the area with race camshafts and large stroke cheater engines. Good question taff2
Tom V.
Old 02-11-2020, 11:19 AM
Jack,I think the blocks were done pre 1961 as everyone except for one has had the 55-60 bellhousing pattern.The complete alu engine I had although it had the 61 pattern the heads had the 55-60 water pattern and as I remember had 1.88 intake.Maybe the word did not get out to the press till 62 I think they were much earlyer.The hemi blocks I have are the first with somekind of performance built into them with the joined lifter bores.Tom
Old 02-12-2020, 03:30 AM
... Why on Earth would they cast a performance ali block-but leave the valley area open?...
The originals were NOT performance blocks. They were merely aluminum copies of the '60 389 block, for PMD to evaluate possibly substituting plated bores for iron liners. The first one I bought from Mickey still had remnants of plating on the bores, and witness marks of thermocouples being used on the decks.
Old 02-12-2020, 03:37 AM
... the blocks were done pre 1961 as everyone except for one has had the 55-60 bellhousing pattern...
Not pre 1961. Pontiac waited until they were done casting 1960 blocks, so they could loan the sand-cast patterns to Harvey Aluminum Company (per phone conversations with Mickey and Fritz).
Old 02-12-2020, 11:10 AM
That make sense!I did not start going to M/Ts place on Cota untill late 63.Tom
Old 03-30-2020, 04:39 PM
Tom Vaught's Avatar
Boost Engineer
Giving credit where credit is due, Mickey Thompson just copied the "Outside Intake Port"
design that BRUCE CROWER first came up with for a Indy Car Engine.
Bruce cast up about 18 sets of heads (based on a Chevy engine design) and the Indy Rule
Makers killed that super high flowing head design.
So Bruce Crower gets the credit for the design and there is lots of info out there to back that statement up.
REST IN PEACE Mr Crower, (passed in 2019). Thanks for the memories at Bonneville in 2001 when I first
met you there and we talked for hours.
Tom V.
Old 03-30-2020, 05:35 PM
77 TRASHCAN's Avatar
Normal 6 cylinder head (Truck application) did not like large amounts of boost, even with an inter-cooler, when run for any period of time.
Some pictures of a 6 cylinder aluminum crossflow head designed for boost.
Engineers do stuff for reasons.
Tom V.
Tom, are those 300 Ford 6 cyl heads??? or something much later, you were involved in???
Shut it off
Shut it off
Old 03-30-2020, 05:56 PM
Tom Vaught's Avatar
Boost Engineer
Those were a Version of the Ford 300 (4.9L) 6 cylinder heads made in Australia.
Actually there were quite a few versions of those aluminum 6 cylinder heads designed and made by the Guys Down Under.
I did the Boosting (Twin Turbos) for the America Ford 300 6 cylinder Prototype Heads that Ford never offered in the USA.
Nino & Gino Novelli did the calibration work and engine fabrication work on the engine.
Tom V.
Old 03-30-2020, 06:04 PM
Tom Vaught's Avatar
Boost Engineer
Bruce Crower Outside Intake Port Heads mentioned in Post # 34
Tom V.
Name:	BruceCrower heads .jpg
  #38
Old 06-03-2020, 05:44 PM
misterp266's Avatar
Came across this today. Not a Pontiac but a Buick nailhead with the intake and exhaust ports swapped and a very unique induction setup.
" Darksiders Rule "
  #39
Old 06-03-2020, 06:09 PM
Tom Vaught's Avatar
Boost Engineer
The Potvin Crank Driven superchargers were always one of my favorite boosting units in the old days.
Street Rods especially. click on pic as usual.
Probably one of the best street rod units as you give up NO front visibility of other vehicles around you.
Tom V.
