Old 12-12-2019, 07:22 PM
gto19's Avatar
gto19 gto19 is offline
Default 1967 gto battery hold down
I have a fairly early build 11-c 1967 gto HO .what does the original battery hold down look like and also what way did the factory install the battery? Negative or positive towards the driver fender ?
Old 12-12-2019, 10:51 PM
Frank R's Avatar
Frank R Frank R is offline
The early production cars used a strap that went over the battery and held with a bolt to the radiator support and a j-bolt to the tray. Later production 67 radiator supports don't have a threaded hole to hold the early battery hold down clamp. The battery mounts with the negative post by the fender.
Old 12-12-2019, 11:51 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Positive post is next to fender.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 12-13-2019, 12:58 AM
242177P's Avatar
242177P 242177P is offline
^^^ What he said. And the really long bolt didn't have a hook.
Old 12-13-2019, 03:55 AM
lust4speed's Avatar
Never figured out why Pontiac put the positive post next to the fender. Seems like it would be much safer to have it away from the steel fender.
Mick Batson
Old 12-13-2019, 10:28 AM
gto19's Avatar
Thanks guys . Yes my radiator support has the threaded hole for the battery hold down . Also if that’s the case about the positive cable near the fender how does the negative run ? Right over the top of the washer bottle ?
ID:	526660   Click image for larger version
Old 12-13-2019, 12:27 PM
Jonsie Jonsie is offline
And what 242177P said. Neg cable should run down to the head next to the bottle
Old 12-13-2019, 03:05 PM
Frank R's Avatar
I ran my cable in front of the washer bottle. My car is a late production 67 and has the clamp on the battery tray.
Old 12-13-2019, 03:25 PM
gto19's Avatar
Ok
Thanks guys . It looks like I need to find the original hold down that bolts to the radiator support and the correct washers and bolts . Maybe someone had a picture of there original set up
Old 12-13-2019, 04:51 PM
Jeff Hamlin's Avatar
Thumbs up All avail from our Host...
