Old 10-31-2016, 12:40 PM
62cat's Avatar
62cat 62cat is offline
Thats going to be one sweet 65. My uncle had a 65 2+2 new.
  #62
Old 10-31-2016, 02:15 PM
MPKind's Avatar
MPKind MPKind is offline
My car's been at the painter for about a year now. Haven't got any news either....
65 Catalina 2D Post
  #63
Old 11-02-2016, 08:08 AM
62cat's Avatar
Default Update
Installed Fabcraft (Mark Williams) Spool,axles with strange rear disc brakes. Also hoosier 275/60/15s on powdercoated weld wheels. Driveshaft is next. Getting close I should have it out this spring.
ID:	439959   Click image for larger version
ID:	439960   Click image for larger version
  #64
Old 11-03-2016, 09:16 AM
Tim Younker Tim Younker is offline
No problems fitting a 275/60/15 tire in the wheelwells??? What size and b/s on your rear wheels? BTW, great project
  #65
Old 11-03-2016, 09:47 AM
mrrat1 mrrat1 is offline
Looks Great!!!!
  #66
Old 11-06-2016, 07:02 PM
62cat's Avatar
Default clearence
Its tight maybe a 1/4inch on each side. Going to take a little off the lip and rework the framerail for some extra. I will let you know on bs had these rims for 23 years this is the 3rd 62 they are going on.
  #67
Old 11-08-2016, 03:01 PM
62cat's Avatar
Wife just helped me bleed brakes. It can stop. Now I need a drive shaft to get it to move.
  #68
Old 04-04-2017, 12:18 PM
62cat's Avatar
Default Exhaust
Exhaust and driveshaft are in. Really all it needs now is a battery and fuel and it will be mobile.
ID:	451462   Click image for larger version
  #69
Old 04-04-2017, 02:24 PM
carcrazy carcrazy is offline
Great looking car...this one is going to be a blast to drive! I'm going to have to find one!
  #70
Old 04-04-2017, 02:30 PM
Willshire's Avatar
Willshire Willshire is offline
I'm way behind. I have the rear window and interior to finish then I can reassemble and drive. This is taken up my time.....
https://youtu.be/5rgb-vbh-is
2 of 3 cars finished.
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
  #71
Old 11-13-2017, 08:01 PM
62cat's Avatar
Default getting close
Went out for roll bar. Then to the upholstery shop. Will be out spring of 18.
  #72
Old 11-14-2017, 09:51 AM
Willshire's Avatar
Got the front seats and rear armrests upholstered, passenger door is getting patched up, primed, filled and ready for paint on the inside. Then on to the drivers before putting the guts in them. Rear window is ready to go in.
  #73
Old 12-04-2017, 01:24 PM
Willshire's Avatar
Welding work is done on the passenger door ready for primer!
  #74
Old 12-04-2017, 02:38 PM
GruntedCatalina GruntedCatalina is offline
i got heads for days! ill join in! while still doing my journal. got new heads stripped and ready for a bath. sent those bad boys to the shop. getting the pockets widened to accomodate the bigger springs for my full head replacement. bigger cam is ready too. just deciding on rings. lol.
  #75
Old 04-23-2018, 09:24 AM
62cat's Avatar
Well my 62 is prowling the streets. Took it for its first ride off the block yesterday. Ran great everything works no leaks lots of looks. Wont be going far with the 4:56 gears though. Need to tighten the steering box and a few other tweaks.
  #76
Old 04-23-2018, 05:35 PM
That's Great......!!
  #77
Old 05-11-2018, 03:39 PM
ho421's Avatar
ho421 ho421 is offline
It lives. Congrats!
  #78
Old 12-12-2019, 09:09 AM
62cat's Avatar
Default update
Been somewhat done for the past 2 years. Going to make some changes. Gears first 4:56 are to much. Two 4s are a must. The single 4 looks lonely.
ID:	526497   Click image for larger version
ID:	526498   Click image for larger version
