Old 03-31-2018, 12:34 PM
james66GTO james66GTO is offline
Default ‘65 Firewall A/C Pictures
Hi, doing final assembly on a ‘65 with A/C - does anybody have firewall pictures to share? Could really use some help, particularly those that have transistorized voltage regulators, thanks !!!
Old 04-04-2018, 04:40 AM
jeff chmura jeff chmura is offline
What exactly are you looking for? Mine has the standard voltage regulator,I believe the transistor regulator bolted in the same place. Let me know,. Jeff
Old 04-04-2018, 12:33 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
1965 GTO with A/C and Transistorized Voltage Regulator.
ID:	479940   Click image for larger version
ID:	479941   Click image for larger version
Old 04-04-2018, 10:16 PM
Thank you very much for the responses - 60sstuff has got it, Eric
Old 11-29-2019, 01:48 PM
Cardo's Avatar
Cardo Cardo is offline
Subscribing.... Starting to assemble mine.
"I know just enough to keep me here, but not enough to get me out"
