Old 11-07-2019, 04:06 PM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
Default Mopar 8-3/4" and Olds-Pontiac 9.3
Pic is a mopar 8-3/4" posi on Marketplace, says from a 66 Super Bee. But it sure looks like an Olds-Pontiac 9.3" posi differential though. I've noticed that when searching for 1963 Pontiac fullsize differential parts on Rockauto, it references many Mopar parts as well...initially I figured it was just part numbering data errors. So are they the same posi diff for both?
https://www.rockauto.com/en/catalog/...ion+yoke,13842
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 11-07-2019, 05:00 PM
John Milner's Avatar
John Milner John Milner is offline
There are pictures of both an 8 3/4 and a 9.3. Internally, I don't believe that there is much that will interchange between the two Dana style carriers. An 8 3/4 carrier for sure won't work with a 9.3 ring gear. The carrier bearings are also different between the two. The splines for the side gears and clutch hubs have a different spline count for sure. An 8 3/4 is a 30 spline. A 9.3 will have a 29 or 31 spline.
Name:	IMG950687 (002).jpg
ID:	523894   Click image for larger version
Name:	IMG950688 (002).jpg
The Following User Says Thank You to John Milner For This Useful Post:
Old 11-07-2019, 05:40 PM
AROWHED's Avatar
So basically Rockauto does have a lot of incorrect Mopar numbers listed for Pontiac? I mean, this one part listed under 1963 Pontiac Catalina, drop-out case, is obviously wrong:
https://www.rockauto.com/en/catalog/...t+case,1001220
And this?
https://www.rockauto.com/en/catalog/...+carrier,13098
Old 11-07-2019, 06:39 PM
The drop out case and carrier information is for sure wrong. I believe the Yoke info was wrong too.
