Old 05-28-2013, 07:02 AM
zeebo's Avatar
zeebo zeebo is offline
Default 73 lemans seatbelt/key buzzer
found the original buzzer for my lemans for the seatbelt/ignition key..plugged it in, and it buzzes with the key in the ignition and the door open, and also when you put it in drive the "fasten belts" light comes on and it continues to buzz..problem is is even after i buckle up, the buzzer and light dont stop...i unplugged the wires going to the seatbelt retractors, but no luck..am i missing something or does one wire on the connector have to be cut to make just the key buzzer work? thanks!!
Old 05-28-2013, 08:52 AM
77 Canamman's Avatar
Try grounding the seat belt wire using a clip lead to see if the light and buzzer stop. The retractor switch is bad, which is common.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 05-28-2013, 02:05 PM
zeebo's Avatar
so i should unplug it from the retractor and ground it and see if it stops? do i have to ground the driver and pass side retractor wire?....what wire should i lift so i can have the buzzer work for the key and not the seatbelt?
Old 05-28-2013, 02:13 PM
If you ground that wire, the buzzer will work when the key is in the ignition cylinder and door open, but should not allow the seat belt lamp or buzzer to work. It is an entirely separate circuit. Yet, it utilizes the same component to perform both functions.
Old 05-28-2013, 09:53 PM
Grand73Am Grand73Am is offline
75 must be different and has 2 separate buzzers, since after owning my 75 LSC for about 9 years, about 2 years ago, my seat belt buzzer started working all of the sudden. Never worked before. Problem was that once it started working, it got to where it wouldn't stop buzzing, even when I buckled up. So, I took the buzzer out. The key buzzer still works though.
Steve F.
Old 05-29-2013, 10:09 AM
1975-77 used two separate buzzer assemblies. The 1975-77 key buzzer was incorporated into the horn relay, and the 1975-76 seat belt buzzer, located next to the horn relay/buzzer used a separate buzzer/warning lamp timer unit that looked like a flasher unit, taped to the wiring harness by the steering column. The 1977 seat belt buzzer used an integral timer.
Old 05-31-2013, 08:38 AM
What was the outcome?
Old 05-31-2013, 09:51 AM
I thought that the 73's also used a weight switch on the seat cushion that also could be making the conection, I know I have one loose in the shop if I can find it, but I don't have a wiring diagram handy so I don't know if they are hooked up in series or parallel with the switch on the retractor.
Am I remembering it correctly?
Old 06-14-2013, 02:05 PM
Here is the spare weight switch I removed from a 73 parts car, finally remembered to look for it.
Old 06-15-2013, 08:36 AM
BillyGoat73's Avatar
BillyGoat73 BillyGoat73 is offline
Jeff, the weight switch is used only on the passenger side. Could the passenger seat be causing the buzzer/fasten seat belt light to come on? Try buckling both front seat belts to narrow down the problem.
1973 GTO 400 4-spd
1973 LeMans GT
Old 06-20-2013, 01:00 PM
zeebo's Avatar
yeah..ill try buckling both belts..i had the front seat recovered and im not sure now if they reinstalled that weight switch..ill look and keep trying to ground the retractors out, etc so i can get my key buzzer to work, i just dont want it to work constantly...right now even when i buckle the drivers belt it wont turn off..with no weight on pass seat.
Old 06-24-2013, 11:17 AM
I just mentioned the weight switch thinking the switch may have shorted out after almost 40 years. I hope you get it sorted out soon.
Thread Tools
Display Modes
