I don't have any iron housings for Pontiac but I do have a couple of iron distributors laying around for Chevrolet on the mezzanine, one has been in the Nomad since the early 70's and when I daily drove that car it always worked flawless. In fact it still has the same set of points in it from the 80's when I was driving it, that thing still fires right up on the first lick and purrs. Always thought the little oil tube with a spring lid was a cool feature. They had service in mind when they built those.
I don't really have any issues with the aluminum housings either. Run the original in the Firebird and the original 480 in the 69 Z. I still see them at swap meets all the time, not the expensive numbers type so much but run of the mill points distributors are pretty much still a dime a dozen at swap meets. Saw a handful of them this weekend for $30-$40. People always dump them thinking the newest wiz bang setup is better. Could always pick up a couple of those, if they feel tight, and most of them seem to be, I'd have no issue going through it and running it for a project for myself. |
I haven't dicked with points in thirty-plus years. I'm amazed that they're getting good press here. I was DONE with points when the HEIs showed-up in the Treasure Yards.
HEI is THE most-reliable electronic ignition ever designed. Parts are readily available even in Small-Town America, and probably Small-town Canada and Mexico, too. Given a choice, I'd start with a used-but-usable GENUINE GM "Delco" HEI core. Of course, there's been no new DELCO HEIs for a couple of decades, and aftermarket parts are becoming questionable...but the same goes for points and condensers. I like the larger spread between plug terminals. Being a bigger unit isn't a bug, it's a feature. And...set up properly, you can run the HEI-compatible spark box of your choice, and when it fails you re-connect the HEI module and drive home. Unilite...Pertronix...NO THANKS. Points distributors make great oil-pump priming tools. |
The Following 3 Users Say Thank You to Schurkey For This Useful Post: | ||
I purchased a Mallory Unilite conversion module in 1985 after the dyno operator sent me down to the speed shop when my Mallory X points were crapping out after about 5,400 RPM. That same Unilite module is still puttering along just fine and my old Sun machine can't go high enough to find out the upper RPM limit.
I wonder if the proponents of points have ever checked them on a distributor machine? Most start taking a dump in the low 4,000 range with very few making it anywhere near 6,000 RPM. Fine for grandma to go to the grocery store back in the day, but the industry has made some progress since the horse and buggy days. We just ran an engine on the Westech dyno and the points distributor was starting to get wonky about 4,400. The interesting thing is the points looked pretty good up to about 5,400 on the machine but on the engine they started giving trouble way below that. Maybe running harmonics that wasn't there on the distributor machine upset the points? I brought along a cast iron distributor with a Fast XRi module and it kept things together for the rest of the day. The first photo is what I usually see when running points at moderately high RPM's on the Sun machine, and the second is with an electronic module installed. Give me Unilite, XRi, MSD, or anything but Pertronix (I wonder if 95% of the bad press about electronic modules doesn't originate from Pertronix failures).
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon. |
The Following User Says Thank You to lust4speed For This Useful Post: | ||
You guys running cheap set of points?
I've had the accel points on the distributor machine, when the sun machine worked, lol and never had issues at higher rpms. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
I've run just about everything at one time or another, and prefer MSD/Holley units. Tolerances on the housings is really good, pickups are really good (mag and/or hall effect), and for the most part are easily setup. The mag pickup MSDs (or other) are very reliable, and are less of a concern than HEI units. All are stable to RPMs most here will never see.
The HEIs wide spread terminals are a good thing, helps prevent crossfire/arc. That is especially a good thing once you start using CD boxes with higher spark. They do make the wide setup for MSD dizzies if you want that, but the regular cap design has ridges that help almost as well. I have not noticed any arc witness marks with them (as long as the parts are fresh & clean). Space is a premium, especially with 3x2/2x4 setups. HEI unit quality is a factor for HEIs, and weights as well as matching weights can get dicey (on OE points setups too). You can skip right past all those drawbacks if you lockout a dizzy (any kind) and use a programmable MSD (or other) unit. I can see using an OE unit if you are trying to stay original or for a 'look', but makes no sense to be to use one on a performance app. And try finding a good performance cap for an OE points dizzy. The few out there are just as expensive as any other performance cap, if not more. Cheap caps with a CD box are eaten very quickly. Or even just a good coil. Same with rotors. .
Little side note: For those interested in the old iron distributors. At the Norwalk swap meet there were well over 100 of them for sale by many, many vendors. If not looking for a specific one with the DELCO band still on it, there were many good cores for $35.00-$50.00. Take it apart, clean and lubricate everything, check the vacuum advance and you have a good starting point without dealing with poor fitting/non- functioning Chinese crap.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
watch Engine Masters ep. Throwing Sparks
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
![]() Quote:
![]() Quote:
![]() Quote:
I haven't checked on the Accel ones in a long time, but suspect they are about the same price. .
Everything is expensive these days so that's pretty much the norm now.
The Echlin Heavy Duty cap with brass terminals and a tan, Heavy Phenolic plastic is $28.00 at any NAPA store. The similar high quality rotor is around $13.00 . Echlin heavy duty points are also available at NAPA. Not sure of cost. Echlin used to make all that stuff for Accel. With Holley buying Accel, who knows where the stuff is made now? Have to assume China.
![]() Quote:
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
The Following User Says Thank You to SRR For This Useful Post: | ||
![]() Quote:
Ran that sucker up to the max RPM spinning so fast that I did not entirely feel safe standing next to it. never a blip, not one. Did you have points made in North Korea then stomp on them ? I tell people to get the medium spring for a reason, they do not bounce ! AND I did my own "dyno" test at the drag strip. Took my Whitmore iron distributor and made a pass. Pulled it and swapped a aluminum dist, changed the springs form the iron one. Both have the advances limited the same. Aluminum had a Petronix. And ran the same pass. My buddies Sun machine could not find the point where the medium spring points bounced ! There were a couple of cars at the track yesterday misfire ring with electronic stuff. Mine has not had a miss fire in 30 years. |
![]() Quote:
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
Well, on misfires, when you hear it, it's hard to blame it on any one thing, but I know when you run a box it eats caps, rotors, and plug wires faster than without.
And I have seen people run plug wires for 10-20 years without changing them, saying 'they still look good' as justification. Just like the tire guys. .
Right now I have the correct aluminum dizzy in my 68 GTO. However when I bought it used in 1976 with 90k miles on it, it had an iron unit installed. I assume replaced at some point by the original owner (he was not mechanically inclined so had to be done at a dealer or shop). I replaced it with aluminum for originality sake ... makes me wonder if the dealer/shop knew something back then and I should go back to the iron unit which I still have. When I was building the engine, half a dozen times I picked up that iron distributor and contemplated if I should use it .. I like iron thing ... but ended up opting for a correct aluminum one.
I'm guessing the original aluminum unit crapped out at some point in the first 90k miles.
#38
Of all the aluminum distributors the 67-68 housings are the best there is out of all of em.
If you look down under the bottom, just under the gear, you will find the wall thickness of the housing where it supports the bushing is about 30% thicker there. They are much more friendly on the bottom bushing. I have no clue why they changed that. It was a win anyhow you looked at it and 69-74 was noticeably thinner. |
The Following 2 Users Say Thank You to Sun Tuned For This Useful Post: | ||
#39
![]() Quote:
There is just something about pressing a bushing into cast iron. What is you bottom gear clearance difference between iron and aluminum ? Exactly what is 'hood oil " ? I have not noticed and oil tubes with spring cups on my 2 Pontiac iron distributors that I have. And can you trigger a MSD box with a HEI with the module unplugged ? Exactly how does that work ? |
#40
![]() Quote:
I’m used to interpreting typos when reading posts here.
Thread Tools | |
Display Modes | |
