Old 04-23-2024, 03:33 PM
joes455 joes455 is offline
Default Got my grandson 4l60e broken down
Looking for a good tech book.Is Cliffs book full of words and wisdom?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 04-23-2024, 04:35 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
I can only speak for his TH400 book, but it was great. I did my first transmission using the tips and information in his book and it works great.
Old 04-23-2024, 04:44 PM
Thank you Scott
Old 04-23-2024, 10:32 PM
Half-Inch Stud's Avatar
4L60 has design deficiencies that lead to failure in use. Either remedy those deficiencies (i dunno what they are) or upgrade to 4L80.
Old 04-24-2024, 07:27 AM
Cliff R's Avatar
Cliff R Cliff R is offline
The 4L60E is a better unit than the early 700-4R/4L60's. The first big change to that transmission came in 1987 when the factory did about a dozen needed upgrades to the original design. The 4L60E's came out a few years later with even more upgrades.
You will need to install solid teflon sealing rings on the reverse drum and input shaft. That will be the biggest challenge. It can be done without buying the special tools needed but a LOT easier if you just take the plunge and buy them.
Haven't done one in quite a while but it is a good ideal to replace the wiring harness inside the pan and even better if you buy new shift solenoids, PR switch and LU solenoid as well........
The Following User Says Thank You to Cliff R For This Useful Post:
Old 04-24-2024, 07:28 AM
Cliff R's Avatar
Old 04-24-2024, 11:40 AM
Schurkey Schurkey is offline
Any transmission I open up, is going to be done with the aid of a ATSG "Techtran" manual, along with whatever D-I-Y/consumer-oriented book(s) I can lay my hands on.
The ATSG manuals are not inexpensive, but they are a detailed wealth of knowledge.
https://www.amazon.com/ATSG-4L60E-Tr.../dp/B00Z1RFENA
Old 04-24-2024, 02:43 PM
unruhjonny's Avatar
just reading this, and I have a small question;
I have a 1991 Chev half ton;
I seem to recall reading that this truck got a better transmission than earlier years.
A friend confirmed RPO's a while ago (he was the manager(?) of a parts department at the time);
I am seeing RPO 'MD8'
Wikipedia (which does have errors) says that the 4L80E was RPO MT1 - but then it goes on to say it was installed in 1991+ GMT400 trucks.
Without crawling under the truck - can anyone tell me if our truck has a 4L80E or 4L60E?
EDIT: I did some more digging, it reads as though the 4L80E was only with larger engines than mine. So mine should be(?) a 4L60E.
1970 Formula 400
Old 04-24-2024, 02:52 PM
Joe's Garage Joe's Garage is offline
Default RPO MD8 is the 700R4 transmission
My son has a 1991 K1500 with the same tranny. It's getting tired.....
Old 04-24-2024, 07:18 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Watch the video on YT from Performabuilt. He really likes the 4L60e even for high HP applications.
The Following User Says Thank You to ponjohn For This Useful Post:
Old 04-25-2024, 10:37 AM
Thanks cliff for posting,just purchased your book hope it helps me.So far fwd drum failed leak test,planetary had deep groove in support shaft,sunshell had some wear.All parts are on order through Gallaxy,inwhick ide Like to give a shoot out to.No real smoking gun found for the 3-4 clutch failure.Did get some info from nickstransmission that a bad tps or maf will be the culprit. Truck had a maf code
Old 04-25-2024, 10:38 AM
