#81
Thanks Big Mike and Alvin. Yes Mike, money on a ride is not wasted. Fortunately too my wife loves it and talks me into not going cheap when I try. She's saved me many times from making foolish decisions.
Does it get any better than cruising? No! |
#82
As we all know it never ends. I have to replace the fuel tank sending unit and would like some opinions, if you've done it yourself better yet. I ordered one from Summit (OPGI) and they just wrote and said it is no longer available so doing a search I see ones from Spectra, Garage-Pro and a couple others.
Would any of you recommend one over the other? Thanks
#83
I've used Spectra in my truck, and possibly my Monte Carlo. So far, so good on both. Don't remember for sure if my Monte Carlo is Spectra or not, but the S-10 is. Works fine for 3 years now. Monte has been about 4 years, but the gas gauge quit working after I put some leftover racing fuel in it from Jeff's boat. Not sure why it hurt the resistor in the gauge unit, nut it always worked great until I put that fuel in it. Ever since, it stays at full most of the time, and sometimes comes down to 3/4 but never less. ??? Fuel pumps on both work fine. I know you don't have the fuel pump part, just saying.
#84
Thanks Paul. The price was so low I was a little concerned about the quality.
